Ana içeriğe geç
2014 Ford F150 Lariat Airbag Clockspring Replacement
Neye ihtiyacın var
  1. 2014 Ford F150 Lariat Airbag Clockspring Replacement, Airbag Clockspring: adım 1, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement, Airbag Clockspring: adım 1, 2 resimden 2.
    • Disconnect the cables to your vehicle battery using a socket wrench and 10mm socket.
    • Wait 10-15 minutes for the capacitors to discharge to ensure that no power can trigger the airbag to deploy.
  2. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 2, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 2, 2 resimden 2.
    • Make sure that your steering wheel and wheels are in the straight position.
  3. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 3, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 3, 2 resimden 2.
    • Find the two holes on the sides of the steering wheel.
    • Insert a small screwdriver into the hole on one side and push to release the clip holding the airbag in place.
    • Repeat on the opposite side to release the airbag.
  4. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 4, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 4, 2 resimden 2.
    • Use a small flathead screwdriver to pop up the tabs on the airbag connector wires and disconnect them.
    • Disconnect the horn wire.
    • Carefully remove the airbag and set aside.
  5. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 5, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 5, 2 resimden 2.
    • Use a socket wrench and 24mm socket to remove the steering wheel bolt.
  6. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 6, 1 resimden 1.
    • Unclip and disconnect the steering wheel wires at the top.
  7. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 7, 1 resimden 1.
    • Pull the steering wheel away from the steering column and set aside.
  8. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 8, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 8, 2 resimden 2.
    • Use a socket wrench and 7mm socket to remove the three screws underneath the steering column that hold the two parts of the steering column covers in place.
    • Separate the steering column covers and push them aside to access the clockspring.
  9. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 9, 1 resimden 1.
    • Unscrew the broken clockspring using a T10 Torx screwdriver to remove the four screws holding it in place.
  10. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 10, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 10, 2 resimden 2.
    • Remove the broken clockspring and set it aside.
  11. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 11, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 11, 2 resimden 2.
    • Install the new clockspring using a T10 Torx screwdriver.
    • Replace the four screws and tighten them.
    • Remove the clockspring lock tab to release the new clockspring mechanism.
  12. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 12, 1 resimden 1.
    • Move the steering column covers back into place and replace the three screws underneath using a socket wrench and 7mm socket.
  13. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 13, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 13, 2 resimden 2.
    • Feed the two airbag wires through the back of the steering wheel to begin replacing it.
    • Replace the steering wheel bolt and tighten it with a socket wrench and 24mm socket.
  14. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 14, 3 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 14, 3 resimden 2. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 14, 3 resimden 3.
    • Reconnect the horn wires and the airbag wires.
    • Push down the tabs on the airbag wire connectors to make sure the connection is good.
  15. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 15, 1 resimden 1.
    • Return the airbag to its place and push it to clip it back in place.
  16. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 16, 1 resimden 1.
    • Reconnect the battery cables.
  17. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 17, 2 resimden 1. 2014 Ford F150 Lariat Airbag Clockspring Replacement: adım 17, 2 resimden 2.
    • Check for a successful installation by cranking the vehicle to see the Engine OK light indicator on the dashboard.
    • Check that the steering wheel control buttons work.
Bitiş Çizgisi
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 44
Her zaman: 110
