Ana içeriğe geç
2014 Hyundai Veloster Headlight Replacement
Neye ihtiyacın var
  1. 2014 Hyundai Veloster Headlight Replacement, Headlight: adım 1, 1 resimden 1.
    • Before beginning this repair, park in a safe, flat space, turn off the car, and put on the emergency brake.
  2. 2014 Hyundai Veloster Headlight Replacement: adım 2, 3 resimden 1. 2014 Hyundai Veloster Headlight Replacement: adım 2, 3 resimden 2. 2014 Hyundai Veloster Headlight Replacement: adım 2, 3 resimden 3.
    • Pull the latch on the drivers side interior to release the lock on the hood.
    • Lift and open the hood of your car until it stays open on its own.
  3. 2014 Hyundai Veloster Headlight Replacement: adım 3, 2 resimden 1. 2014 Hyundai Veloster Headlight Replacement: adım 3, 2 resimden 2.
    • Your headlights are located on the left and right sides of the front of your vehicle and are covered by a cap.
  4. 2014 Hyundai Veloster Headlight Replacement: adım 4, 3 resimden 1. 2014 Hyundai Veloster Headlight Replacement: adım 4, 3 resimden 2. 2014 Hyundai Veloster Headlight Replacement: adım 4, 3 resimden 3.
    • Twist the cap to the left and pull it off.
    • Twist the headlight to the left and pull it out too.
  5. 2014 Hyundai Veloster Headlight Replacement: adım 5, 3 resimden 1. 2014 Hyundai Veloster Headlight Replacement: adım 5, 3 resimden 2. 2014 Hyundai Veloster Headlight Replacement: adım 5, 3 resimden 3.
    • Pull the headlight bulb out of the socket.
  6. 2014 Hyundai Veloster Headlight Replacement: adım 6, 3 resimden 1. 2014 Hyundai Veloster Headlight Replacement: adım 6, 3 resimden 2. 2014 Hyundai Veloster Headlight Replacement: adım 6, 3 resimden 3.
    • Plug the new headlight into the socket and place it back into its space.
    • Don't touch the bulb glass with your fingers because the oil from your hands will cause the glass to degrade and wear faster or shatter.
    • Lock it into place by twisting it slightly to the right.
    • Put the cap back on and twist it slightly to the right to lock it in place.
  7. 2014 Hyundai Veloster Headlight Replacement: adım 7, 3 resimden 1. 2014 Hyundai Veloster Headlight Replacement: adım 7, 3 resimden 2. 2014 Hyundai Veloster Headlight Replacement: adım 7, 3 resimden 3.
    • Close your hood.
    • Turn your car on and test your new headlight to see if it works.
    • Congratulations!
Sonuç
Bir başkası bu kılavuzu tamamladı.
Enrique Cisneros
166 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 98
Her zaman: 3,019
