Ana içeriğe geç
2014 Toyota Highlander Key Fob Battery Replacement
  1. 2014 Toyota Highlander Key Fob Battery Replacement, Battery: adım 1, 3 resimden 1. 2014 Toyota Highlander Key Fob Battery Replacement, Battery: adım 1, 3 resimden 2. 2014 Toyota Highlander Key Fob Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the key by pressing the button on the side.
    • Make sure the red alarm button is face-up so that the button you need to press is on the left side of the plastic layer.
  2. 2014 Toyota Highlander Key Fob Battery Replacement: adım 2, 2 resimden 1. 2014 Toyota Highlander Key Fob Battery Replacement: adım 2, 2 resimden 2.
    • Insert tweezers into the notch where the key was.
    • You can use any kind of tweezer you have at home as long as it fits into the notch.
  3. 2014 Toyota Highlander Key Fob Battery Replacement: adım 3, 1 resimden 1.
    • Apply a small amount of pressure to the tweezer, so you can use them to pop the plastic layer open.
  4. 2014 Toyota Highlander Key Fob Battery Replacement: adım 4, 2 resimden 1. 2014 Toyota Highlander Key Fob Battery Replacement: adım 4, 2 resimden 2.
    • Check the front and back of the green circuit to locate the battery.
  5. 2014 Toyota Highlander Key Fob Battery Replacement: adım 5, 3 resimden 1. 2014 Toyota Highlander Key Fob Battery Replacement: adım 5, 3 resimden 2. 2014 Toyota Highlander Key Fob Battery Replacement: adım 5, 3 resimden 3.
    • Using the pair of tweezers, remove the battery from the device.
Sonuç
Muhamad Razeq
121 İtibar
1 Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 19
Son 30 gün: 93
Her zaman: 1,675
