Ana içeriğe geç
2015-2019 Dodge Charger Tail Light Replacement
Neye ihtiyacın var
  1. 2015-2019 Dodge Charger Tail Light Replacement, Tail Light: adım 1, 1 resimden 1.
    • Remove the rear plastic panel cover located inside the trunk by pushing the panel towards the center of the car.
  2. 2015-2019 Dodge Charger Tail Light Replacement: adım 2, 2 resimden 1. 2015-2019 Dodge Charger Tail Light Replacement: adım 2, 2 resimden 2.
    • Remove the plastic screw securing the inner lining of the trunk by pulling outwards.
    • Do not use excess force as it can damage the screw.
  3. 2015-2019 Dodge Charger Tail Light Replacement: adım 3, 2 resimden 1. 2015-2019 Dodge Charger Tail Light Replacement: adım 3, 2 resimden 2.
    • Remove the plastic pin by prying it outwards using a pry bar to free the inner lining.
    • Pull back the inner lining to gain access to the screws securing the tail lights in place.
  4. 2015-2019 Dodge Charger Tail Light Replacement: adım 4, 3 resimden 1. 2015-2019 Dodge Charger Tail Light Replacement: adım 4, 3 resimden 2. 2015-2019 Dodge Charger Tail Light Replacement: adım 4, 3 resimden 3.
    • Remove both 8 mm nuts securing the tail lights in place using an 8 mm wrench.
    • Remove the nuts carefully as they may fall between the gaps which can be difficult to reach.
  5. 2015-2019 Dodge Charger Tail Light Replacement: adım 5, 1 resimden 1.
    • Remove the connector by squeezing both sides and pulling outwards.
  6. 2015-2019 Dodge Charger Tail Light Replacement: adım 6, 2 resimden 1. 2015-2019 Dodge Charger Tail Light Replacement: adım 6, 2 resimden 2.
    • Remove the plastic cover by pulling outwards so that the tail light can slide out.
  7. 2015-2019 Dodge Charger Tail Light Replacement: adım 7, 2 resimden 1. 2015-2019 Dodge Charger Tail Light Replacement: adım 7, 2 resimden 2.
    • Grab both sides of the tail light firmly and pull it out.
  8. 2015-2019 Dodge Charger Tail Light Replacement: adım 8, 1 resimden 1.
    • Slide the replacement tail light back in firmly.
  9. 2015-2019 Dodge Charger Tail Light Replacement: adım 9, 3 resimden 1. 2015-2019 Dodge Charger Tail Light Replacement: adım 9, 3 resimden 2. 2015-2019 Dodge Charger Tail Light Replacement: adım 9, 3 resimden 3.
    • Insert the connector back to the tail light.
    • Screw the 8 mm nuts onto the bolts by hand before tightening with a 8 mm wrench.
  10. 2015-2019 Dodge Charger Tail Light Replacement: adım 10, 3 resimden 1. 2015-2019 Dodge Charger Tail Light Replacement: adım 10, 3 resimden 2. 2015-2019 Dodge Charger Tail Light Replacement: adım 10, 3 resimden 3.
    • Push the plastic pin back into the hole to secure the side inner lining.
    • Push the plastic screw back into the hole to secure the bottom inner lining.
    • Push the rear plastic panel cover back on.
  11. 2015-2019 Dodge Charger Tail Light Replacement: adım 11, 1 resimden 1.
    • Start the vehicle to test if the tail light works.
Sonuç
Repeat the same steps to replace the other tail light.
Bir başkası bu kılavuzu tamamladı.
Asad Raza
217 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 192
Her zaman: 5,171
