Ana içeriğe geç
2015-2019 Toyota Highlander Headlight Bulbs Replacement
Neye ihtiyacın var
  1. 2015-2019 Toyota Highlander Headlight Bulbs Replacement, Headlight Bulbs: adım 1, 2 resimden 1. 2015-2019 Toyota Highlander Headlight Bulbs Replacement, Headlight Bulbs: adım 1, 2 resimden 2.
    • Locate lever to open the hood.
    • Once the hood is opened, Cover the working area with a towel.
    • The towel will protect your car from any potential scratches while working on the head lights.
  2. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 2, 2 resimden 1. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 2, 2 resimden 2.
    • Locate all the low-beam and high-beam head lights that need to be replaced.
  3. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 3, 3 resimden 1. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 3, 3 resimden 2. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 3, 3 resimden 3.
    • To give yourself more space to work with on the side where the windshield washer reservoir resides, we are going to relocate the nozzle of said reservoir.
    • Unlock the clip by pressing from both sides of the clip.
    • While pressing the clip, pull the nozzle up to detach it.
    • Use a plastic roll to tie the nozzle of the reservoir to the oil cap.
  4. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 4, 3 resimden 1. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 4, 3 resimden 2. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 4, 3 resimden 3.
    • Locate the high-beam electrical cable connected to the light.
    • To disconnect the electrical cable, press the clips on both sides and pull the cable down.
  5. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 5, 3 resimden 1. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 5, 3 resimden 2. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 5, 3 resimden 3.
    • Now that the electrical cable is out, we can now remove the lightbulb.
    • First, turn the bulb counterclockwise.
    • Once the bulb is turned in that direction, you can now pull the bulb out of the socket.
  6. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 6, 3 resimden 1. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 6, 3 resimden 2. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 6, 3 resimden 3.
    • Install the high-beam LED light bulb.
    • The light bulb has three small mounts on the side; make sure to put it in the right position.
    • Place the LED bulb in the socket.
    • Once the bulb is in the socket, turn the bulb clockwise.
    • Repeat steps four, five, and six for the other high-beam bulb.
  7. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 7, 2 resimden 1. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 7, 2 resimden 2.
    • For the low-beam bulb, we need to remove the OEM cover first to access the bulb.
    • To remove the OEM cover turn it counterclockwise and pull it out.
  8. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 8, 3 resimden 1. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 8, 3 resimden 2. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 8, 3 resimden 3.
    • Locate the electric cable of the low-beam light bulb.
    • First, press down on the clip
    • While pressing down the clip, pull down cable down to remove the cable
  9. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 9, 3 resimden 1. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 9, 3 resimden 2. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 9, 3 resimden 3.
    • To remove the bulb from the socket, turn the bulb counter-clockwise.
    • Once turned all the way, take the bulb out of the socket.
  10. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 10, 3 resimden 1. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 10, 3 resimden 2. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 10, 3 resimden 3.
    • Same as the high beam bulb, the low beam light bulb also have three small mounts.
    • Carefully put the LED light bulb in the right position on those small mounts.
    • Once the bulb is in the socket, turn the bulb clockwise to secure it.
    • Repeat steps seven, eight, nine, and ten for the other low-beam bulb.
  11. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 11, 3 resimden 1. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 11, 3 resimden 2. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 11, 3 resimden 3.
    • Once the low-beam and high-beam bulbs are installed on both sides, you must now reconnect all of the electrical cables.
    • Make sure to connect all the cables with the corresponding electrical terminals.
    • Push on both sides of the connecter until the lock is in the position. (They will make a click sound.)
  12. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 12, 3 resimden 1. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 12, 3 resimden 2. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 12, 3 resimden 3.
    • In order to organize the residue cables, you can use zip ties
    • Tie the cables according to the bulb they are connected to.
    • Once the cables are tied together, you can secure the cables to the frame of the car.
  13. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 13, 3 resimden 1. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 13, 3 resimden 2. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 13, 3 resimden 3.
    • We will now put back the nozzle of the windshield washer reservoir.
    • Untie the nozzle and place the secure lock in the small hole on the small metal mount.
    • Gently push it down to lock. (It will make a click sound when it's locked.)
  14. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 14, 3 resimden 1. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 14, 3 resimden 2. 2015-2019 Toyota Highlander Headlight Bulbs Replacement: adım 14, 3 resimden 3.
    • These are the before and after results: The old light bulbs are yellow light, and the new LEDs are white light.
Sonuç
The upgrade of LED light significantly improved the brightness of the vehicle's headlights. It also makes the car look more modern with clear white light. It is essential to buy the correct light bulb that is compatible with your car. You can search for the make and model including the year of the vehicle; this will help you to find the right LED light.
2 farklı kişi bu kılavuzu tamamladı.
JohnDong
245 İtibar
1 Kılavuz yazıldı
3 Yorum
hi, if you don't mind, please also provide the light bulb you used for High and low beams. and thank you for your post!
Kevin Chou - Yanıt
Thanks for the article. Everyone kindly note. Please do NOT forget to adjust the low beams down when installing LEDs. Projector and non projector housings are built for halogen original sources. When installing LEDs the shape of beam is much sharper and blinds other drivers if not adjusted properly. Every vehicle has adjustment screws please ALWAYS adjust your lights down when replacing with LEDs, for any type of car! google how to find the screws and take the time to perform this important step after installing LEDs!
wingman2552 - Yanıt
Does this also replace the daytime running lights
Antonio Hernandez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 44
Son 30 gün: 284
Her zaman: 7,967
