Ana içeriğe geç
2015 Jeep Patriot Tail/ Brake Light Replacement
Neye ihtiyacın var
  1. 2015 Jeep Patriot Tail/ Brake Light Replacement, Jeep Patriot Tail/ Brake Light Replacement: adım 1, 2 resimden 1. 2015 Jeep Patriot Tail/ Brake Light Replacement, Jeep Patriot Tail/ Brake Light Replacement: adım 1, 2 resimden 2.
    • Open the trunk and locate the fender clips.
    • These are located near the tail lights.
  2. 2015 Jeep Patriot Tail/ Brake Light Replacement: adım 2, 3 resimden 1. 2015 Jeep Patriot Tail/ Brake Light Replacement: adım 2, 3 resimden 2. 2015 Jeep Patriot Tail/ Brake Light Replacement: adım 2, 3 resimden 3.
    • Use the 3/16 inch flathead screwdriver to remove the top fender clip holding the tail light on.
  3. 2015 Jeep Patriot Tail/ Brake Light Replacement: adım 3, 1 resimden 1.
    • Remove the lower fender clip.
    • This will release the tail light so be careful.
  4. 2015 Jeep Patriot Tail/ Brake Light Replacement: adım 4, 2 resimden 1. 2015 Jeep Patriot Tail/ Brake Light Replacement: adım 4, 2 resimden 2.
    • Remove the tail light to expose the light bulb.
  5. 2015 Jeep Patriot Tail/ Brake Light Replacement: adım 5, 2 resimden 1. 2015 Jeep Patriot Tail/ Brake Light Replacement: adım 5, 2 resimden 2.
    • Twist the light bulb to remove it from the holder.
    • Replace the old bulb with the new one. make sure to twist the new bulb to secure it.
    • Do not touch the new light bulb with your bare hands as the oil from your fingers will cause it to degrade faster and possibly shatter.
  6. 2015 Jeep Patriot Tail/ Brake Light Replacement: adım 6, 2 resimden 1. 2015 Jeep Patriot Tail/ Brake Light Replacement: adım 6, 2 resimden 2.
    • Align the two pegs on the tail light housing with the matching holes on the car.
  7. 2015 Jeep Patriot Tail/ Brake Light Replacement: adım 7, 2 resimden 1. 2015 Jeep Patriot Tail/ Brake Light Replacement: adım 7, 2 resimden 2.
    • Reinsert the top and bottom fender clips.
Sonuç
Yadira Vera
145 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 43
Son 30 gün: 158
Her zaman: 2,713
