Ana içeriğe geç
2015 Nissan Altima Mass Air Flow Sensor Replacement
Neye ihtiyacın var
  1. 2015 Nissan Altima Mass Air Flow Sensor Replacement, Mass Air Flow Sensor: adım 1, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement, Mass Air Flow Sensor: adım 1, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement, Mass Air Flow Sensor: adım 1, 3 resimden 3.
    • Open the driver's side door where the hood release is located.
  2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 2, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 2, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 2, 3 resimden 3.
    • Connect a scanner by clicking it into the obd2 port.
  3. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 3, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 3, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 3, 3 resimden 3.
    • Run the code through the scanner.
  4. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 4, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 4, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 4, 3 resimden 3.
    • Open up the hood latch.
    • Locate front hood holder and lift it up for safety.
  5. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 5, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 5, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 5, 3 resimden 3.
    • Locate the battery and a positive and negative terminal.
    • The Positive terminal.
    • The Negative terminal.
    • Be careful risk of electrical shock
  6. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 6, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 6, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 6, 3 resimden 3.
    • Unscrew the positive terminal with a 10mm wrench by turning it counterclockwise.
  7. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 7, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 7, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 7, 3 resimden 3.
    • Unscrew the negative terminal with a 10mm wrench by turning it counterclockwise.
  8. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 8, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 8, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 8, 3 resimden 3.
    • Unplug the mass air flow sensor by pushing in the pull tabs and pulling upwards.
  9. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 9, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 9, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 9, 3 resimden 3.
    • Remove the screws with a Phillips #1 screwdriver by turning them counterclockwise.
  10. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 10, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 10, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 10, 3 resimden 3.
    • Remove the old sensor by pulling it off and replace with a new one.
  11. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 11, 2 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 11, 2 resimden 2.
    • Screw back on the screws with a Phillips #1 screwdriver by turning them clockwise.
  12. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 12, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 12, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 12, 3 resimden 3.
    • Click the sensor in place.
    • Plug in the battery by following steps 6 and 7 in reverse order.
  13. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 13, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 13, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 13, 3 resimden 3.
    • Run the scanner again and make sure no check engine light is on and no trouble codes appear.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 110
Her zaman: 538
