Ana içeriğe geç
2015 Nissan Altima Mass Air Flow Sensor Replacement
Neye ihtiyacın var
  1. 2015 Nissan Altima Mass Air Flow Sensor Replacement, Mass Air Flow Sensor: adım 1, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement, Mass Air Flow Sensor: adım 1, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement, Mass Air Flow Sensor: adım 1, 3 resimden 3.
    • Open the driver's side door where the hood release is located.
  2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 2, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 2, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 2, 3 resimden 3.
    • Connect a scanner by clicking it into the obd2 port.
  3. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 3, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 3, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 3, 3 resimden 3.
    • Run the code through the scanner.
  4. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 4, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 4, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 4, 3 resimden 3.
    • Open up the hood latch.
    • Locate front hood holder and lift it up for safety.
  5. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 5, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 5, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 5, 3 resimden 3.
    • Locate the battery and a positive and negative terminal.
    • The Positive terminal.
    • The Negative terminal.
    • Be careful risk of electrical shock
  6. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 6, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 6, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 6, 3 resimden 3.
    • Unscrew the positive terminal with a 10mm wrench by turning it counterclockwise.
  7. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 7, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 7, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 7, 3 resimden 3.
    • Unscrew the negative terminal with a 10mm wrench by turning it counterclockwise.
  8. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 8, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 8, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 8, 3 resimden 3.
    • Unplug the mass air flow sensor by pushing in the pull tabs and pulling upwards.
  9. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 9, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 9, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 9, 3 resimden 3.
    • Remove the screws with a Phillips #1 screwdriver by turning them counterclockwise.
  10. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 10, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 10, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 10, 3 resimden 3.
    • Remove the old sensor by pulling it off and replace with a new one.
  11. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 11, 2 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 11, 2 resimden 2.
    • Screw back on the screws with a Phillips #1 screwdriver by turning them clockwise.
  12. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 12, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 12, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 12, 3 resimden 3.
    • Click the sensor in place.
    • Plug in the battery by following steps 6 and 7 in reverse order.
  13. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 13, 3 resimden 1. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 13, 3 resimden 2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: adım 13, 3 resimden 3.
    • Run the scanner again and make sure no check engine light is on and no trouble codes appear.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 24
Son 30 gün: 105
Her zaman: 493
