Ana içeriğe geç
2015 Toyota Highlander Cabin Air Filter Replacement
  1. 2015 Toyota Highlander Cabin Air Filter Replacement, 2015 Toyota Highlander Cabin Air Filter: adım 1, 1 resimden 1.
    • Make sure car is off by removing key or moving it to the off position as shown.
  2. 2015 Toyota Highlander Cabin Air Filter Replacement: adım 2, 2 resimden 1. 2015 Toyota Highlander Cabin Air Filter Replacement: adım 2, 2 resimden 2.
    • Move to the passenger side of the car and open the passenger side door.
  3. 2015 Toyota Highlander Cabin Air Filter Replacement: adım 3, 1 resimden 1.
    • Open and empty the glovebox.
  4. 2015 Toyota Highlander Cabin Air Filter Replacement: adım 4, 2 resimden 1. 2015 Toyota Highlander Cabin Air Filter Replacement: adım 4, 2 resimden 2.
    • Detach the latch at the lower right-hand side of the glovebox.
    • Pull it outwards and unclip it with your finger as shown.
  5. 2015 Toyota Highlander Cabin Air Filter Replacement: adım 5, 1 resimden 1.
    • Push in both upper sides of the glovebox to unhook the stops.
    • This should cause the entire glovebox to come down and detach.
  6. 2015 Toyota Highlander Cabin Air Filter Replacement: adım 6, 1 resimden 1.
    • Remove the front plastic cover as shown. Pull on both upper tabs using your fingers.
  7. 2015 Toyota Highlander Cabin Air Filter Replacement: adım 7, 1 resimden 1.
    • Swing down the front plastic cover.
    • Unhook the tabs from both sides of the rear plastic cover and pull it out.
  8. 2015 Toyota Highlander Cabin Air Filter Replacement: adım 8, 2 resimden 1. 2015 Toyota Highlander Cabin Air Filter Replacement: adım 8, 2 resimden 2.
    • Remove the old cabin air filter from the vehicle.
    • Clean any debris found in the cabin air filter compartment.
  9. 2015 Toyota Highlander Cabin Air Filter Replacement: adım 9, 1 resimden 1.
    • Insert the new cabin air filter into the compartment.
    • Be mindful of the airflow direction arrow. The airflow arrow should point upwards as shown.
Sonuç
Prabhmeet Brar
169 İtibar
1 Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 69
Her zaman: 515
