Giriş
This guide will walk you through the short and easy steps of replacing an expired brake light bulb in your 2016-2021 Camaro. A flat-head screwdriver and set of pliers are highly recommended for the repair, but not necessary. A new bulb will be needed to replace the old one.
Neye ihtiyacın var
Using either the button on your vehicle's key fob, or the button on the driver's side door, open the trunk.
Go to the rear of the vehicle and lift the rear trunk lid until it reaches its highest position and locks out.
Bir başkası bu kılavuzu tamamladı.
