Ana içeriğe geç
2016 Dodge Charger Spark Plug Replacement
Neye ihtiyacın var
  1. 2016 Dodge Charger Spark Plug Replacement, Spark plugs: adım 1, 3 resimden 1. 2016 Dodge Charger Spark Plug Replacement, Spark plugs: adım 1, 3 resimden 2. 2016 Dodge Charger Spark Plug Replacement, Spark plugs: adım 1, 3 resimden 3.
    • Unlatch and lift the hood of your car.
    • Locate the coil packs covering the spark plugs.
    • Depending on engine, there will be 6 to 8 coil packs.
  2. 2016 Dodge Charger Spark Plug Replacement: adım 2, 2 resimden 1. 2016 Dodge Charger Spark Plug Replacement: adım 2, 2 resimden 2.
    • Before you begin to remove the coil packs, one will be blocked by the air intake.
    • Use a 5/16 wrench to remove the single air intake bracket.
    • Use a flathead screwdriver to loosen the air intake hose clamp.
    • Move the intake hose and filter box over to reach the last coil pack.
  3. 2016 Dodge Charger Spark Plug Replacement: adım 3, 2 resimden 1. 2016 Dodge Charger Spark Plug Replacement: adım 3, 2 resimden 2.
    • To remove a coil pack, two bolts will need to be removed. Use a 3/8 inch drive ratchet with a 10 mm socket to remove the first two bolts.
  4. 2016 Dodge Charger Spark Plug Replacement: adım 4, 2 resimden 1. 2016 Dodge Charger Spark Plug Replacement: adım 4, 2 resimden 2.
    • Gently pull on the coil pack to remove it, and lay it to the side.
    • Once a coil pack has been removed, we will have access to 2 of the old spark plugs.
  5. 2016 Dodge Charger Spark Plug Replacement: adım 5, 2 resimden 1. 2016 Dodge Charger Spark Plug Replacement: adım 5, 2 resimden 2.
    • To remove the old spark plugs, use a socket wrench with a 5/8 spark plug socket and an extension to help reach the spark plugs.
  6. 2016 Dodge Charger Spark Plug Replacement: adım 6, 3 resimden 1. 2016 Dodge Charger Spark Plug Replacement: adım 6, 3 resimden 2. 2016 Dodge Charger Spark Plug Replacement: adım 6, 3 resimden 3.
    • Before installing new spark plugs, use a gap gauge to measure the gap at the bottom of the spark plug.
    • The gap gauge of a Dodge Charger should be 0.043 to 0.045.
    • Once you have checked the gap of the spark plug it can be installed. Then swap the ratchet to tighten and use it with the extension and 5/8 spark plug socket to install the new spark plugs.
  7. 2016 Dodge Charger Spark Plug Replacement: adım 7, 1 resimden 1.
    • Once new spark plugs have been installed, move the coil pack back into place and use the ratchet with the 10mm socket to tighten them down.
  8. 2016 Dodge Charger Spark Plug Replacement: adım 8, 1 resimden 1.
    • After using the steps provided above and all 16 spark plugs have been replaced with the coil packs inserted, you will need to reinstall the air intake.
    • Reinsert the air intake and use the ratchet to tighten the bolt.
    • Use the flathead screwdriver to tighten the intake hose clamp.
Sonuç
Congratulations, you have successfully replaced the spark plugs of a 2016 Dodge Charger.
Keep in mind that it is recommended by manufacturer to change them every 30000 miles. By using this guide to change them yourself you will save roughly 200 dollars versus going to an auto repair shop.
Daniel Brown
157 İtibar
1 Kılavuz yazıldı
Bir Yorum
Thank you for your information and pictures but this is not for all of them and the left side of engine is way harder than right side please include that as well!
Kasra Mehdizadeh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 100
Her zaman: 2,363
