Giriş
This guide is a fairly easy fix for the 2016 Dodge Dart SXT that doesn’t require much technical knowledge about the car. Many automotive stores will usually lend out the tools needed for these types of repairs. When working with any electrical system within a car, make sure to properly disconnect the car battery before proceeding with any repair. Even with low risk systems like the dome lights, it ensures your safety and mitigates all risk of electrical shock. After this procedure, reconnect the battery, and all the lights should work as normal.
Neye ihtiyacın var
Use a spudger to gently pry down on the clear plastic covers until they pop off.
The newly replaced dome lights should retain all prior functionality, turning on when a door is opened or by pressing on the cover itself.
