Ana içeriğe geç
2016 Nissan Altima Key Fob Battery Replacement
Neye ihtiyacın var
  1. 2016 Nissan Altima Key Fob Battery Replacement, Battery: adım 1, 3 resimden 1. 2016 Nissan Altima Key Fob Battery Replacement, Battery: adım 1, 3 resimden 2. 2016 Nissan Altima Key Fob Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the little switch up on the back of the key. While doing so, remove the physical key that is stored inside the fob by pulling away.
  2. 2016 Nissan Altima Key Fob Battery Replacement: adım 2, 1 resimden 1.
    • Insert a flathead screwdriver or prying tool into the small notch located at the bottom of the key fob.
    • Carefully rotate the flathead counterclockwise to pry apart the two halves of the fob.
  3. 2016 Nissan Altima Key Fob Battery Replacement: adım 3, 1 resimden 1.
    • Pry out the battery with a flathead to avoid skin contact with electrical components.
    • Make sure to avoid touching the motherboard.
  4. 2016 Nissan Altima Key Fob Battery Replacement: adım 4, 1 resimden 1.
    • Now carefully place the new battery onto the silver platter.
    • Keep in mind positive side of the battery will be facing downward, while negative side will be facing towards you.
  5. 2016 Nissan Altima Key Fob Battery Replacement: adım 5, 1 resimden 1.
    • Line up the parts in order to secure the key.
    • Press down until the case makes a "click" sound.
  6. 2016 Nissan Altima Key Fob Battery Replacement: adım 6, 1 resimden 1.
    • Finally, insert the physical key back into the fob to complete your replacement.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Giovanni Avalos
214 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
Great job , thanks . Sent wife info and believe it she figured it out, thanks.
Erik - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 105
Her zaman: 6,143
