Ana içeriğe geç
2016 Prius Windshield Wiper Replacement
Neye ihtiyacın var
  1. 2016 Prius Windshield Wiper Replacement, Windshield Wiper: adım 1, 1 resimden 1.
    • Purchase the appropriate wiper blades for a 2016 Toyota Prius.
    • Typically, you’ll need a 26-inch blade for the driver side and a 16-inch blade for the passenger side.
    • Check the car’s manual or the packaging to confirm.
  2. 2016 Prius Windshield Wiper Replacement: adım 2, 1 resimden 1.
    • Wipe down the wiper arms and the surrounding area with a microfiber cloth.
  3. 2016 Prius Windshield Wiper Replacement: adım 3, 3 resimden 1. 2016 Prius Windshield Wiper Replacement: adım 3, 3 resimden 2. 2016 Prius Windshield Wiper Replacement: adım 3, 3 resimden 3.
    • Be cautious, as the arm is spring loaded and letting it snap back can crack the windshield or damage your wipers.
    • You can put a towel down against the windshield if damaging it is a concern.
    • Carefully pull the wiper arm away from the windshield until it locks in an upright position.
    • To remove the old wiper blade, press the small tab or release clip at the point where the wiper blade connects to the wiper arm and slide it off.
  4. 2016 Prius Windshield Wiper Replacement: adım 4, 2 resimden 1. 2016 Prius Windshield Wiper Replacement: adım 4, 2 resimden 2.
    • Open the new windshield wiper
    • Remove the incorrect adapter piece by firmly holding the wiper in one hand and use upward force to pry it off.
  5. 2016 Prius Windshield Wiper Replacement: adım 5, 3 resimden 1. 2016 Prius Windshield Wiper Replacement: adım 5, 3 resimden 2. 2016 Prius Windshield Wiper Replacement: adım 5, 3 resimden 3.
    • Find the bag of additional adapter pieces that come with the windshield wiper and pull out the one labeled #6.
    • Make sure the guidance arrows are pointing in the same direction.
    • To attach the #6 adapter, align the adapter and blade and push using downward force until you hear them click into place.
  6. 2016 Prius Windshield Wiper Replacement: adım 6, 2 resimden 1. 2016 Prius Windshield Wiper Replacement: adım 6, 2 resimden 2.
    • Now that the correct adapter is attached, align the new wiper blade with the hook on the wiper arm.
    • Slide the wiper blade in until you hear a click, indicating it’s securely locked in place.
    • Double-check that it’s fastened to avoid it detaching while in use.
  7. 2016 Prius Windshield Wiper Replacement: adım 7, 1 resimden 1.
    • Slowly lower the wiper arm back onto the windshield.
    • Be gentle, as the arm can snap back if released quickly, potentially damaging the windshield or the new blade.
    • To change the second windshield wiper blade, repeat steps 2-6
Sonuç
Congratulations, you've learned how to successfully replace your windshield wipers! Safe driving!
Mari Crampton
175 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 1-1, Vidal-Chiesa Fall 2024 UC Davis, Team 1-1, Vidal-Chiesa Fall 2024 üyesi
UCD-VIDAL-CHIESA-F24S1G1
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 53
Her zaman: 175
