Ana içeriğe geç
2016 Toyota Camry Key Fob Battery Replacement
Neye ihtiyacın var
  1. 2016 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: adım 1, 3 resimden 1. 2016 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: adım 1, 3 resimden 2. 2016 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: adım 1, 3 resimden 3.
    • Take a coin and wedge it between both halves of the key fob where the keychain notch is. Push against the indent until the fob begins to lift open.
    • Take care not to lose the buttons, as they may fall out.
  2. 2016 Toyota Camry Key Fob Battery Replacement: adım 2, 3 resimden 1. 2016 Toyota Camry Key Fob Battery Replacement: adım 2, 3 resimden 2. 2016 Toyota Camry Key Fob Battery Replacement: adım 2, 3 resimden 3.
    • Look for the notch where it says “use coin to open." Push against the indent with your coin to separate the pieces.
    • Remove the middle console.
  3. 2016 Toyota Camry Key Fob Battery Replacement: adım 3, 2 resimden 1. 2016 Toyota Camry Key Fob Battery Replacement: adım 3, 2 resimden 2.
    • Use your fingernail to pry around the battery until it pops out.
    • When inserting the new battery, make sure that the positive side is facing up.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Thanks and nicely done. The small plastic clips that hold the battery can be tricky.
Michael Lynn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 78
Son 30 gün: 412
Her zaman: 8,830
