Ana içeriğe geç
2016 Toyota Camry Sun Visor Replacement
Neye ihtiyacın var
  1. 2016 Toyota Camry Sun Visor Replacement, Sun Visor: adım 1, 2 resimden 1. 2016 Toyota Camry Sun Visor Replacement, Sun Visor: adım 1, 2 resimden 2.
    • Using your hands, remove the protective cap to make the sun visor screws visible.
  2. 2016 Toyota Camry Sun Visor Replacement: adım 2, 3 resimden 1. 2016 Toyota Camry Sun Visor Replacement: adım 2, 3 resimden 2. 2016 Toyota Camry Sun Visor Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #2 screwdriver or drill bit above the screws and align the drill bit to the head of the screw.
    • Gently remove the screws from their position.
  3. 2016 Toyota Camry Sun Visor Replacement: adım 3, 1 resimden 1.
    • Detach the sun visor once all screws have been removed.
  4. 2016 Toyota Camry Sun Visor Replacement: adım 4, 2 resimden 1. 2016 Toyota Camry Sun Visor Replacement: adım 4, 2 resimden 2.
    • Place and hold the new sun visor.
    • Begin to drill in the same screws you removed in step 3.
    • Note: You may need assistance from a second person.
  5. 2016 Toyota Camry Sun Visor Replacement: adım 5, 1 resimden 1.
    • Once the sun visor is secure, place the protective cap back on.
  6. 2016 Toyota Camry Sun Visor Replacement: adım 6, 2 resimden 1. 2016 Toyota Camry Sun Visor Replacement: adım 6, 2 resimden 2.
    • Move the sun visor into different positions to verify proper installation.
    • The sun visor should NOT feel weak or jiggle around.
Bitiş Çizgisi
Angel Malta
277 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 39
Her zaman: 650
