Ana içeriğe geç
2017 Honda Accord Headlight Replacement
Neye ihtiyacın var
  1. 2017 Honda Accord Headlight Replacement, Headlight: adım 1, 3 resimden 1. 2017 Honda Accord Headlight Replacement, Headlight: adım 1, 3 resimden 2. 2017 Honda Accord Headlight Replacement, Headlight: adım 1, 3 resimden 3.
    • Pull the Hood Latch lever inside the car, located under the steering wheel.
    • Lift the hood while pressing up on the lever under the front of the hood.
  2. 2017 Honda Accord Headlight Replacement: adım 2, 2 resimden 1. 2017 Honda Accord Headlight Replacement: adım 2, 2 resimden 2.
    • Lift up the hood prop rod and insert it into the hole on the underside of the hood.
  3. 2017 Honda Accord Headlight Replacement: adım 3, 2 resimden 1. 2017 Honda Accord Headlight Replacement: adım 3, 2 resimden 2.
    • Use a 1/4" ratcheting wrench and a 10mm socket to loosen the bolt on the negative terminal head.
    • Lift the terminal up off of the battery and place it to the side.
  4. 2017 Honda Accord Headlight Replacement: adım 4, 1 resimden 1.
    • Use the clip remover tool to pry the clip up to remove it.
  5. 2017 Honda Accord Headlight Replacement: adım 5, 3 resimden 1. 2017 Honda Accord Headlight Replacement: adım 5, 3 resimden 2. 2017 Honda Accord Headlight Replacement: adım 5, 3 resimden 3.
    • Use a 1/4" ratcheting wrench and a 10mm socket to remove the three bolts.
  6. 2017 Honda Accord Headlight Replacement: adım 6, 1 resimden 1.
    • Use a 1/4" ratcheting wrench, a 6" extension and a 10mm socket to remove the last bolt.
  7. 2017 Honda Accord Headlight Replacement: adım 7, 2 resimden 1. 2017 Honda Accord Headlight Replacement: adım 7, 2 resimden 2.
    • Gently pull the headlight out.
  8. 2017 Honda Accord Headlight Replacement: adım 8, 2 resimden 1. 2017 Honda Accord Headlight Replacement: adım 8, 2 resimden 2.
    • Press the tab on the connector and pull. Do this for all 4 connectors.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 25
Son 30 gün: 81
Her zaman: 4,272
