Ana içeriğe geç
2018 Hyundai Tucson Low Beam Headlight Bulb Replacement
  1. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement, Low Beam Headlight Bulb: adım 1, 3 resimden 1. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement, Low Beam Headlight Bulb: adım 1, 3 resimden 2. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement, Low Beam Headlight Bulb: adım 1, 3 resimden 3.
    • Ensure your vehicle is turned off.
    • Do not touch the new lightbulb with your hands. The oil on your hands can damage the bulb and cause it to fail prematurely.
    • Inside the driver’s side of the vehicle, pull the hood latch to unlock the hood.
    • Open the hood.
    • Secure the hood using the hood support rod.
  2. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement: adım 2, 1 resimden 1.
    • Locate the low-beam headlight assembly.
    • The low-beam assembly is on the outermost side of the vehicle.
  3. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement: adım 3, 3 resimden 1. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement: adım 3, 3 resimden 2. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement: adım 3, 3 resimden 3.
    • On the low-beam headlight assembly, unscrew the assembly cap.
    • Remove the assembly cap, and then set it aside.
  4. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement: adım 4, 1 resimden 1.
    • Reach into the low-beam headlight assembly, and then grab the headlight housing.
    • Twist the headlight housing counterclockwise to unlock it.
  5. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement: adım 5, 3 resimden 1. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement: adım 5, 3 resimden 2. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement: adım 5, 3 resimden 3.
    • Pull out the headlight housing from the headlight assembly.
    • Grab the lightbulb and then pull it out from the headlight housing.
  6. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement: adım 6, 3 resimden 1. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement: adım 6, 3 resimden 2. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement: adım 6, 3 resimden 3.
    • Open the package of the new lightbulb.
    • Grab the lightbulb by the base.
    • Attach the new lightbulb to the headlight housing.
  7. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement: adım 7, 3 resimden 1. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement: adım 7, 3 resimden 2. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement: adım 7, 3 resimden 3.
    • Place the headlight housing into the headlight assembly.
    • Twist the headlight housing clockwise to lock it.
  8. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement: adım 8, 1 resimden 1.
    • Screw the assembly cap to the low-beam headlight assembly.
  9. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement: adım 9, 1 resimden 1.
    • Turn on your vehicle.
    • Turn on your lights.
    • Move to the front of the vehicle, and then visually verify that the new low-beam lightbulb works.
    • If the new low-beam lightbulb does not work, turn off your vehicle, check the headlight housing connections, and then reverify.
    • Turn off your vehicle.
  10. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement: adım 10, 2 resimden 1. 2018 Hyundai Tucson Low Beam Headlight Bulb Replacement: adım 10, 2 resimden 2.
    • Disengage the hood support rod.
    • Close the hood.
Bitiş Çizgisi
TereBear
181 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 49
Son 30 gün: 312
Her zaman: 660
