Ana içeriğe geç
2018-Present Toyota Corolla Engine Air Filter Replacement
Neye ihtiyacın var
  1. 2018-Present Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: adım 1, 2 resimden 1. 2018-Present Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: adım 1, 2 resimden 2.
    • Park your Toyota corolla on a flat surface. Turn off engine. Remove keys from ignition.
    • Open the hood after the engine is cool.
  2. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 2, 3 resimden 1. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 2, 3 resimden 2. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 2, 3 resimden 3.
    • Lift and secure the hood.
  3. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 3, 3 resimden 1. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 3, 3 resimden 2. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 3, 3 resimden 3.
    • Unclip the housing clip to open the housing.
  4. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 4, 3 resimden 1. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 4, 3 resimden 2. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 4, 3 resimden 3.
    • Unclip the housing's second clip on the other side of the housing.
  5. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 5, 2 resimden 1. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 5, 2 resimden 2.
    • Lift the housing.
  6. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 6, 2 resimden 1. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 6, 2 resimden 2.
    • Remove the old air filter by gently taking the filter out from under the housing.
  7. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 7, 2 resimden 1. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 7, 2 resimden 2.
    • Install the new air filter by placing it into the housing.
    • Check to make sure it is properly oriented with the rubber rim facing up.
  8. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 8, 2 resimden 1. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 8, 2 resimden 2.
    • Close the housing.
  9. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 9, 3 resimden 1. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 9, 3 resimden 2. 2018-Present Toyota Corolla Engine Air Filter Replacement: adım 9, 3 resimden 3.
    • Resecure the clips on both sides of the housing.
Sonuç
Final Checks:
  • Check to ensure that the housing is clipped securely in its place.
  • Start your vehicle to ensure that it is running smoothly.
  • Check dashboard to ensure there is no warning light flashing.
Bir başkası bu kılavuzu tamamladı.
Quoc Nguyen
169 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 2-7, Andersen Winter 2024 UC Davis, Team 2-7, Andersen Winter 2024 üyesi
UCD-ANDERSEN-W24S2G7
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 21
Son 30 gün: 85
Her zaman: 283
