Ana içeriğe geç
2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement
Neye ihtiyacın var
  1. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement, Battery: adım 1, 2 resimden 1. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Press the button or slide the groove to release the emergency key.
  2. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: adım 2, 2 resimden 1. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: adım 2, 2 resimden 2.
    • After removing the key blade, locate the slot or indentation.
    • Insert a flathead into the slot and gently twist to open the key fob.
  3. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: adım 3, 2 resimden 1. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: adım 3, 2 resimden 2.
    • Carefully lift the cover to reveal the internal components.
  4. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: adım 4, 1 resimden 1.
    • Use a non-metallic tool or your hand to gently pry out the old battery.
    • Dispose of the old battery following local regulations.
  5. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: adım 5, 1 resimden 1.
    • Place the new battery into the designated slot with the correct polarity.
    • Ensure the battery is securely in place.
  6. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: adım 6, 2 resimden 1. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: adım 6, 2 resimden 2.
    • Align the cover with the key fob and press down to snap it into place.
    • Ensure the key fob is securely closed.
    • Slide the key blade back into its slot until it clicks into place.
    • Press any button on the key fob to verify that the new battery is functioning.
    • If the light blinks on the front of the fob key, the battery replacement is successful.
Sonuç
sepi
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 137
Her zaman: 712
