Ana içeriğe geç
2019 Toyota Highlander Cabin Air Filter Replacement
  1. 2019 Toyota Highlander Cabin Air Filter Replacement, Cabin Air Filter: adım 1, 2 resimden 1. 2019 Toyota Highlander Cabin Air Filter Replacement, Cabin Air Filter: adım 1, 2 resimden 2.
    • Open the glove compartment and take everything out.
  2. 2019 Toyota Highlander Cabin Air Filter Replacement: adım 2, 3 resimden 1. 2019 Toyota Highlander Cabin Air Filter Replacement: adım 2, 3 resimden 2. 2019 Toyota Highlander Cabin Air Filter Replacement: adım 2, 3 resimden 3.
    • Press the tabs on the sides of the glove compartment until they are released.
    • Please press the sides gently to avoid any damage.
  3. 2019 Toyota Highlander Cabin Air Filter Replacement: adım 3, 1 resimden 1.
    • Once the tabs are released, remove the entire glove compartment.
  4. 2019 Toyota Highlander Cabin Air Filter Replacement: adım 4, 3 resimden 1. 2019 Toyota Highlander Cabin Air Filter Replacement: adım 4, 3 resimden 2. 2019 Toyota Highlander Cabin Air Filter Replacement: adım 4, 3 resimden 3.
    • Open the second cover. Position your finger where the red circle is pointing in the first image, then lower it.
  5. 2019 Toyota Highlander Cabin Air Filter Replacement: adım 5, 3 resimden 1. 2019 Toyota Highlander Cabin Air Filter Replacement: adım 5, 3 resimden 2. 2019 Toyota Highlander Cabin Air Filter Replacement: adım 5, 3 resimden 3.
    • Press the tabs on the side of the third cover. Remove the cover.
    • Do not apply heavy force to prevent damage.
  6. 2019 Toyota Highlander Cabin Air Filter Replacement: adım 6, 3 resimden 1. 2019 Toyota Highlander Cabin Air Filter Replacement: adım 6, 3 resimden 2. 2019 Toyota Highlander Cabin Air Filter Replacement: adım 6, 3 resimden 3.
    • Pull the filter out. If the filter is really dirty, then replace it with a new one. Otherwise, clean the filter and return it to position.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 59
Son 30 gün: 234
Her zaman: 2,589
