Giriş
If you're looking to improve the performance of your 2020 Ford F-150 3.5L, this guide will walk you through replacing and upgrading the cold air intake with a Roush cold air intake.
This step-by-step tutorial provides all the instructions you need to complete the upgrade quickly and efficiently.
Please note that in Step 5, the two 8mm bolts cannot be fully removed, as they are welded to the fittings.
Before starting, ensure your truck is turned off and in park for safety. Additionally, disconnect the vehicle's battery to avoid any electrical issues while working under the hood.
Neye ihtiyacın var
Open the hood and ensure it is securely propped up.
Next, loosen the clamps on the factory air intake using a flathead screwdriver.
Bir başkası bu kılavuzu tamamladı.
