Ana içeriğe geç
2020 Honda Civic Cabin Lights Replacement
Neye ihtiyacın var
  1. 2020 Honda Civic Cabin Lights Replacement, Cabin Lights: adım 1, 3 resimden 1. 2020 Honda Civic Cabin Lights Replacement, Cabin Lights: adım 1, 3 resimden 2. 2020 Honda Civic Cabin Lights Replacement, Cabin Lights: adım 1, 3 resimden 3.
    • Open the trunk.
    • The cabin light for the trunk will be located on the roof of the trunk.
  2. 2020 Honda Civic Cabin Lights Replacement: adım 2, 3 resimden 1. 2020 Honda Civic Cabin Lights Replacement: adım 2, 3 resimden 2. 2020 Honda Civic Cabin Lights Replacement: adım 2, 3 resimden 3.
    • Wedge a prying tool into the crevice between the light and the roof. Push the tool in to release the light compartment.
    • Carefully pull the light bulb out, using a prying tool if necessary.
    • The light bulb may be hot.
    • Hold the compartment up while you grab your LED light bulb.
  3. 2020 Honda Civic Cabin Lights Replacement: adım 3, 3 resimden 1. 2020 Honda Civic Cabin Lights Replacement: adım 3, 3 resimden 2. 2020 Honda Civic Cabin Lights Replacement: adım 3, 3 resimden 3.
    • Insert the new LED bulb into the light socket until it turns on.
    • When the LED remains constantly on without flickering, the light bulb is correctly inserted into the socket.
  4. 2020 Honda Civic Cabin Lights Replacement: adım 4, 3 resimden 1. 2020 Honda Civic Cabin Lights Replacement: adım 4, 3 resimden 2. 2020 Honda Civic Cabin Lights Replacement: adım 4, 3 resimden 3.
    • Reinstall the light compartment back into position.
    • Align the tabs and push the compartment into the frame until it clicks securely.
    • When the compartment is fully inserted, the cabin light replacement in the trunk is complete. Proceed to the rear passenger cabin light.
  5. 2020 Honda Civic Cabin Lights Replacement: adım 5, 3 resimden 1. 2020 Honda Civic Cabin Lights Replacement: adım 5, 3 resimden 2. 2020 Honda Civic Cabin Lights Replacement: adım 5, 3 resimden 3.
    • The cabin light is located in the rear passenger seats.
    • You need to be inside the car to complete the replacement for this cabin light.
  6. 2020 Honda Civic Cabin Lights Replacement: adım 6, 3 resimden 1. 2020 Honda Civic Cabin Lights Replacement: adım 6, 3 resimden 2. 2020 Honda Civic Cabin Lights Replacement: adım 6, 3 resimden 3.
    • Wedge a prying tool into the corner of the frame.
    • Once the cover pops out, use the end of another prying tool to fully remove it.
  7. 2020 Honda Civic Cabin Lights Replacement: adım 7, 3 resimden 1. 2020 Honda Civic Cabin Lights Replacement: adım 7, 3 resimden 2. 2020 Honda Civic Cabin Lights Replacement: adım 7, 3 resimden 3.
    • With the cover completely removed, begin removing the light bulb.
    • If the light bulb is difficult to remove, use your prying tool to assist in removing the light bulb.
  8. 2020 Honda Civic Cabin Lights Replacement: adım 8, 3 resimden 1. 2020 Honda Civic Cabin Lights Replacement: adım 8, 3 resimden 2. 2020 Honda Civic Cabin Lights Replacement: adım 8, 3 resimden 3.
    • Grab one of your LED light bulbs and insert it into the socket until it is securely in place.
  9. 2020 Honda Civic Cabin Lights Replacement: adım 9, 3 resimden 1. 2020 Honda Civic Cabin Lights Replacement: adım 9, 3 resimden 2. 2020 Honda Civic Cabin Lights Replacement: adım 9, 3 resimden 3.
    • Turn on the switch to ensure the light bulb turns on, indicating the step was completely correctly.
    • After confirming it works, align the cover with the clips and push it into place until you hear a clicking sound.
  10. 2020 Honda Civic Cabin Lights Replacement: adım 10, 3 resimden 1. 2020 Honda Civic Cabin Lights Replacement: adım 10, 3 resimden 2. 2020 Honda Civic Cabin Lights Replacement: adım 10, 3 resimden 3.
    • Move to the to cabin lights in the front of the driver and passenger seat.
    • Each front cabin light has its own switch. We will start with the driver's side light.
    • Wedge the prying tool into the crevice on the inside of the cover.
    • Push carefully to release and remove the cover.
  11. 2020 Honda Civic Cabin Lights Replacement: adım 11, 3 resimden 1. 2020 Honda Civic Cabin Lights Replacement: adım 11, 3 resimden 2. 2020 Honda Civic Cabin Lights Replacement: adım 11, 3 resimden 3.
    • After removing the cover, start pulling out the light bulb from its socket.
    • Once the light bulb is removed, grab your new LED light bulb.
  12. 2020 Honda Civic Cabin Lights Replacement: adım 12, 2 resimden 1. 2020 Honda Civic Cabin Lights Replacement: adım 12, 2 resimden 2.
    • Insert your new LED light bulb into the socket until it is completely in place.
  13. 2020 Honda Civic Cabin Lights Replacement: adım 13, 3 resimden 1. 2020 Honda Civic Cabin Lights Replacement: adım 13, 3 resimden 2. 2020 Honda Civic Cabin Lights Replacement: adım 13, 3 resimden 3.
    • Once you are done inserting the new LED light bulb into the socket, begin placing the cover back on.
    • Align the cover with the clips on the frame and push it in until you hear clicking sound.
    • After that, you're done with the driver's side cabin light. Move on to the passenger side.
  14. 2020 Honda Civic Cabin Lights Replacement: adım 14, 3 resimden 1. 2020 Honda Civic Cabin Lights Replacement: adım 14, 3 resimden 2. 2020 Honda Civic Cabin Lights Replacement: adım 14, 3 resimden 3.
    • The passenger side steps are the same as the driver's side.
    • Grab your prying tool, insert it into the wedge on the inside of the cover, and push inward.
    • Once the cover is removed, you can begin removing the light bulb.
  15. 2020 Honda Civic Cabin Lights Replacement: adım 15, 3 resimden 1. 2020 Honda Civic Cabin Lights Replacement: adım 15, 3 resimden 2. 2020 Honda Civic Cabin Lights Replacement: adım 15, 3 resimden 3.
    • After removing the old light bulb, grab your new LED light bulb replacement.
    • With the new light bulb in hand, insert the new light bulb into the socket.
    • Make sure the light bulb is correctly seated in the socket.
  16. 2020 Honda Civic Cabin Lights Replacement: adım 16, 2 resimden 1. 2020 Honda Civic Cabin Lights Replacement: adım 16, 2 resimden 2.
    • After inserting the new LED light bulb into the socket. You can begin putting the cover back on.
    • Align the cover with the clips around the frame and push inward.
    • This step is complete when you hear a clicking sound.
  17. 2020 Honda Civic Cabin Lights Replacement: adım 17, 3 resimden 1. 2020 Honda Civic Cabin Lights Replacement: adım 17, 3 resimden 2. 2020 Honda Civic Cabin Lights Replacement: adım 17, 3 resimden 3.
    • Once you have finished, all your cabin lights should look like this when turned on.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Ismael Nunez-Candia
265 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 80
Her zaman: 222
