Ana içeriğe geç
2021 Chevrolet Silverado Tail Light Replacement
Neye ihtiyacın var
  1. 2021 Chevrolet Silverado Tail Light Replacement, Tail Light: adım 1, 3 resimden 1. 2021 Chevrolet Silverado Tail Light Replacement, Tail Light: adım 1, 3 resimden 2. 2021 Chevrolet Silverado Tail Light Replacement, Tail Light: adım 1, 3 resimden 3.
    • Open the tailgate.
    • Remove the top and bottom T15 screws from each side of the tail lights.
    • Gently remove the tail lights by pulling outward.
  2. 2021 Chevrolet Silverado Tail Light Replacement: adım 2, 3 resimden 1. 2021 Chevrolet Silverado Tail Light Replacement: adım 2, 3 resimden 2. 2021 Chevrolet Silverado Tail Light Replacement: adım 2, 3 resimden 3.
    • Unplug the sockets and remove the reverse light bulb from the tail light.
  3. 2021 Chevrolet Silverado Tail Light Replacement: adım 3, 3 resimden 1. 2021 Chevrolet Silverado Tail Light Replacement: adım 3, 3 resimden 2. 2021 Chevrolet Silverado Tail Light Replacement: adım 3, 3 resimden 3.
    • Plug the brake lights connector.
    • Twist and secure the socket tightly.
    • Plug in the turn signal bulb connector. Twist and secure tightly.
  4. 2021 Chevrolet Silverado Tail Light Replacement: adım 4, 3 resimden 1. 2021 Chevrolet Silverado Tail Light Replacement: adım 4, 3 resimden 2. 2021 Chevrolet Silverado Tail Light Replacement: adım 4, 3 resimden 3.
    • Plug in the parking lights connector. Twist and secure the socket tightly.
    • Plug in the TURN SIGNALS connector. Please follow the same steps for the other side of the tail lights.
    • Make sure all the connections are plugged and tight. Also ensure that the caps are sealed.
  5. 2021 Chevrolet Silverado Tail Light Replacement: adım 5, 2 resimden 1. 2021 Chevrolet Silverado Tail Light Replacement: adım 5, 2 resimden 2.
    • First, remove the reverse light bulb from the vehicle.
    • Then, connect the socket to the reverse light connector from the new tail light.
  6. 2021 Chevrolet Silverado Tail Light Replacement: adım 6, 3 resimden 1. 2021 Chevrolet Silverado Tail Light Replacement: adım 6, 3 resimden 2. 2021 Chevrolet Silverado Tail Light Replacement: adım 6, 3 resimden 3.
    • Lastly, plug the vehicle’s tail light socket to new tail light connector.
  7. 2021 Chevrolet Silverado Tail Light Replacement: adım 7, 3 resimden 1. 2021 Chevrolet Silverado Tail Light Replacement: adım 7, 3 resimden 2. 2021 Chevrolet Silverado Tail Light Replacement: adım 7, 3 resimden 3.
    • Gently push the tail light into the mounting position and use T15 screwdriver to tighten the top and bottom screws.
    • Repeat the same process for the other side of the tail light.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 29
Son 30 gün: 137
Her zaman: 1,142
