Giriş
In this simple guide, you will learn how replace the cabin air filter on your 2021 Hyundai Elantra.
The cabin air filter in your car is responsible for filtering all the air that is released through the A/C. If you’ve noticed recently that the air smells off, if your car has a bad smell in general, or you’ve driven 10,000km or about 6,200 miles, it may be time to change your cabin air filter.
This guide is very simple, and the entire process should take you less than 10 minutes. Just make sure you have purchased an air filter that is compatible with your car. For the 2021 Elantra, there is a link for a suitable air filter in this guide.
There are no tools needed to complete this guide.
Neye ihtiyacın var
Locate your cabin air filter. For the Hyundai Elantra 2021, it is located behind the glove compartment.
Open your glove compartment.
Remove your glove compartment from its seat by pushing the sides of it inwards.
Doing so will reveal a rubber holder, which must be dislodged in order to fully remove your glove compartment.
Directly behind your glove compartment, you should find the cabin air filter compartment.
By the end of this guide, you should have been able to replace your Hyundai Elantra 2021 cabin air filter properly. Enjoy clean, fresh air!
3 farklı kişi bu kılavuzu tamamladı.
