Ana içeriğe geç
2021 Hyundai Veloster Spark Plug Replacement
Neye ihtiyacın var
  1. 2021 Hyundai Veloster Spark Plug Replacement, Spark Plug: adım 1, 3 resimden 1. 2021 Hyundai Veloster Spark Plug Replacement, Spark Plug: adım 1, 3 resimden 2. 2021 Hyundai Veloster Spark Plug Replacement, Spark Plug: adım 1, 3 resimden 3.
    • Pull the hood latch inside your vehicle.
  2. 2021 Hyundai Veloster Spark Plug Replacement: adım 2, 3 resimden 1. 2021 Hyundai Veloster Spark Plug Replacement: adım 2, 3 resimden 2. 2021 Hyundai Veloster Spark Plug Replacement: adım 2, 3 resimden 3.
    • Open the hood and use the hood stick to prop it up securely.
  3. 2021 Hyundai Veloster Spark Plug Replacement: adım 3, 1 resimden 1.
    • Use a 10 mm socket wrench to remove the bolt from the negative battery terminal.
    • Disconnecting the battery ensures safety during the replacement procedure.
    • Once disconnected, securely position the negative battery terminal away from any metal surfaces to prevent accidental reconnection.
  4. 2021 Hyundai Veloster Spark Plug Replacement: adım 4, 3 resimden 1. 2021 Hyundai Veloster Spark Plug Replacement: adım 4, 3 resimden 2. 2021 Hyundai Veloster Spark Plug Replacement: adım 4, 3 resimden 3.
    • Carefully detach the engine cover with your hands and set it aside.
  5. 2021 Hyundai Veloster Spark Plug Replacement: adım 5, 3 resimden 1. 2021 Hyundai Veloster Spark Plug Replacement: adım 5, 3 resimden 2. 2021 Hyundai Veloster Spark Plug Replacement: adım 5, 3 resimden 3.
    • Identify the spark plugs on top of the engine.
    • Remove the bolts securing the spark plugs using a 10 mm socket, extension, and wrench.
    • Gently pull out the spark plug wires.
    • Exercise care when pulling out the spark plug wires to prevent dislodging any dirt or contaminants that may fall into the engine.
  6. 2021 Hyundai Veloster Spark Plug Replacement: adım 6, 3 resimden 1. 2021 Hyundai Veloster Spark Plug Replacement: adım 6, 3 resimden 2. 2021 Hyundai Veloster Spark Plug Replacement: adım 6, 3 resimden 3.
    • Utilize a spark plug socket, extension, and wrench to carefully remove all four spark plugs.
  7. 2021 Hyundai Veloster Spark Plug Replacement: adım 7, 1 resimden 1.
    • Verify the proper factory gap on the new spark plugs using a Spark Plug Gap Gauge.
    • Gap range: .022mm-.028mm
  8. 2021 Hyundai Veloster Spark Plug Replacement: adım 8, 1 resimden 1.
    • Place a new spark plug into the spark plug socket.
    • Torque each spark plug to 18 ft-lbs.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mario Aguirre Romero
157 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 46
Her zaman: 440
