Ana içeriğe geç
2023 Honda Civic Side Mirror Replacement
Neye ihtiyacın var
  1. 2023 Honda Civic Side Mirror Replacement, Side Mirror: adım 1, 1 resimden 1.
    • Use a plastic pry bar to gently open the door interior panel.
    • Avoid excessive force to prevent damage or scratches.
  2. 2023 Honda Civic Side Mirror Replacement: adım 2, 1 resimden 1.
    • Use a flat-head screwdriver to remove the screws securing the door, then disconnect the rearview mirror and side mirror control button.
  3. 2023 Honda Civic Side Mirror Replacement: adım 3, 1 resimden 1.
    • Pull the bottom of the door interior panel with your hands to disengage it from the fixing clips.
  4. 2023 Honda Civic Side Mirror Replacement: adım 4, 2 resimden 1. 2023 Honda Civic Side Mirror Replacement: adım 4, 2 resimden 2.
    • Tear a small gap in the sound insulation cotton by hand.
    • Find the interface between the side mirror and the power supply in the car, then disconnect it.
  5. 2023 Honda Civic Side Mirror Replacement: adım 5, 2 resimden 1. 2023 Honda Civic Side Mirror Replacement: adım 5, 2 resimden 2.
    • Using a hex wrench screwdriver, firmly loosen the screws holding the side view mirror inside the door.
    • Remove the side mirror.
    • Be careful not to let the mirror move into the door gap after loosening the screw.
  6. 2023 Honda Civic Side Mirror Replacement: adım 6, 2 resimden 1. 2023 Honda Civic Side Mirror Replacement: adım 6, 2 resimden 2.
    • Install the new side mirror and reattach the screws.
  7. 2023 Honda Civic Side Mirror Replacement: adım 7, 2 resimden 1. 2023 Honda Civic Side Mirror Replacement: adım 7, 2 resimden 2.
    • Connect the new side-view mirror to the power supply and control bar, and then reinstall the door panel.
  8. 2023 Honda Civic Side Mirror Replacement: adım 8, 2 resimden 1. 2023 Honda Civic Side Mirror Replacement: adım 8, 2 resimden 2.
    • Test the side mirror control buttons to ensure they work and the mirrors move left and right.
    • Check the dashboard for errors. If everything works, the task is successfully completed.
    • Blind spot monitoring and other features require on-road testing.
Bitiş Çizgisi
yifan shi
157 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 25
Son 30 gün: 59
Her zaman: 393
