Ana içeriğe geç
360fly 4K Battery Replacement
Neye ihtiyacın var
  1. 360fly 4K Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
  2. 360fly 4K Battery Replacement: adım 2, 1 resimden 1.
    • Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
  3. 360fly 4K Battery Replacement: adım 3, 2 resimden 1. 360fly 4K Battery Replacement: adım 3, 2 resimden 2.
    • Gently pry the plastic ring from around the charging plate with the metal spudger.
    • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
  4. 360fly 4K Battery Replacement: adım 4, 1 resimden 1.
    • Remove the five 2 mm screws using a T4 screwdriver.
    • Pull off the charging plate assembly.
  5. 360fly 4K Battery Replacement: adım 5, 2 resimden 1. 360fly 4K Battery Replacement: adım 5, 2 resimden 2.
    • Gently pry the plug off the port on the circuit board with a plastic opening tool.
    • Remove the four 2 mm screws using a T4 screwdriver.
    • Remove the circuit board from the device.
  6. 360fly 4K Battery Replacement: adım 6, 3 resimden 1. 360fly 4K Battery Replacement: adım 6, 3 resimden 2. 360fly 4K Battery Replacement: adım 6, 3 resimden 3.
    • Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
    • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
    • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Potential for device damage: Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jacob Herron
463 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S5-G3, Baechle Fall 2017 IUPUI, Team S5-G3, Baechle Fall 2017 üyesi
IUPUI-BAECHLE-F17S5G3
3 Üyeler
4 Yorum
Wich one battery Can I use to replace It?
Marco Pereira - Yanıt
Where can i purchase a battery
john hernandez - Yanıt
I would like to purchase a 360 fly battery
Where can I buy the battery?
Mark - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 2,306
