Ana içeriğe geç
3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement
Neye ihtiyacın var
  1. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement, Battery: adım 1, 1 resimden 1.
    • Power off the drone by holding down the power button.
    • Remove the battery by disconnecting it from the main battery connector.
    • Press the power button again to ensure all electricity is discharged.
    • This step is imperative as it is dangerous to handle drone components with a running current!
  2. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement, Gimbal: adım 2, 3 resimden 1. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement, Gimbal: adım 2, 3 resimden 2. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement, Gimbal: adım 2, 3 resimden 3.
    • If your drone is equipped with it, remove the video transmitter.
    • Disconnect all cables from the gimbal.
    • If your drone has neither the gimbal or video transmitter, you can skip this step.
  3. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement: adım 3, 2 resimden 1. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement: adım 3, 2 resimden 2.
    • Unscrew the 16 mm screw attaching the gimbal mount to the body of the drone using the 3 mm Hex screwdriver/key.
  4. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement: adım 4, 2 resimden 1. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement: adım 4, 2 resimden 2.
    • Rotate the drone 180 degrees.
    • Unscrew the other 16mm gimbal mount screw using the 3 mm Hex screwdriver/key.
  5. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement: adım 5, 1 resimden 1.
    • Remove the gimbal mount from the body of the drone.
  6. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement, Bottom Shell: adım 6, 2 resimden 1. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement, Bottom Shell: adım 6, 2 resimden 2.
    • Remove the eight 11mm screws attaching the underbody of the drone using the 2mm Hex screwdriver/key.
  7. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement: adım 7, 3 resimden 1. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement: adım 7, 3 resimden 2. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement: adım 7, 3 resimden 3.
    • Remove the two larger, 12mm screws attached to the Go Pro mount using the 3mm Hex screwdriver/key.
    • Lift to remove the mount.
  8. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement: adım 8, 3 resimden 1. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement: adım 8, 3 resimden 2. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement: adım 8, 3 resimden 3.
    • Feed both wires through the grill of the bottom shell.
    • Lift to remove the shell.
    • There are two cables tethering the shell to the body of the drone. It is difficult and unnecessary to remove them. Simply lay the shell to the side.
  9. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement, Electronic Speed Controller (ESC) and Power Distribution Board (PDB): adım 9, 3 resimden 1. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement, Electronic Speed Controller (ESC) and Power Distribution Board (PDB): adım 9, 3 resimden 2. 3DR Iris Plus Quadcopter Electronic Speed Controller (ESC) and Power Distribution Board (PDB) Replacement, Electronic Speed Controller (ESC) and Power Distribution Board (PDB): adım 9, 3 resimden 3.
    • Unscrew the four 4mm screws that hold the board to the central drone assembly using the 2mm Hex screwdriver/key.
    • Desolder the 12 motor wires.
    • For more information on soldering and desoldering wires, please visit the How to Solder and Desolder Connections guide.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Evan Witulski
349 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G5, Regan Winter 2020 Cal Poly, Team S7-G5, Regan Winter 2020 üyesi
CPSU-REGAN-W20S7G5
5 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 12
Her zaman: 551
