Ana içeriğe geç
4-Stroke Small Gas Engine Spark Plug Replacement
Neye ihtiyacın var
  1. 4-Stroke Small Gas Engine Spark Plug Replacement, Spark Plug: adım 1, 3 resimden 1. 4-Stroke Small Gas Engine Spark Plug Replacement, Spark Plug: adım 1, 3 resimden 2. 4-Stroke Small Gas Engine Spark Plug Replacement, Spark Plug: adım 1, 3 resimden 3.
    • Tug the Spark Plug Cap from the top of the Spark Plug (between the OHV housing and the exhaust manifold) with your hands to remove it.
  2. 4-Stroke Small Gas Engine Spark Plug Replacement: adım 2, 2 resimden 1. 4-Stroke Small Gas Engine Spark Plug Replacement: adım 2, 2 resimden 2.
    • Make sure the engine is turned off and cool to the touch before completing this step.
    • Using a ¼ “ socket and Handheld Ratchet, loosen the three screws holding the Exhaust Manifold Heat Shield on.
  3. 4-Stroke Small Gas Engine Spark Plug Replacement: adım 3, 3 resimden 1. 4-Stroke Small Gas Engine Spark Plug Replacement: adım 3, 3 resimden 2. 4-Stroke Small Gas Engine Spark Plug Replacement: adım 3, 3 resimden 3.
    • Once the Heat Shield is removed, grip the Spark Plug’s threaded diameter with an Adjustable wrench and rotate counterclockwise.
    • Alternatively, you may use a 5/8" wrench or 5/8" deep socket along with a handheld ratchet.
    • Remove the Champion RC12YC Spark Plug from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jack Linchey
277 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S25-G15, Maness Spring 2018 Cal Poly, Team S25-G15, Maness Spring 2018 üyesi
CPSU-MANESS-S18S25G15
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 58
Son 30 gün: 82
Her zaman: 1,457
