Ana içeriğe geç
42" LG TV LED Strip Replacement Tutorial
Videoya Genel Bakış
  1. 42" LG TV LED Strip Replacement Tutorial, LED Strip Replacement Tutorial: adım 1, 1 resimden 1.
    • Remove the screws from the rear of the television, as well as the back cover.
    FixBot'a Sor
    Yorum Ekle
  2. 42" LG TV LED Strip Replacement Tutorial: adım 2, 1 resimden 1.
    • Remove the screws that connect the IR sensor to the mainboard to remove and detach it.
    FixBot'a Sor
    Yorum Ekle
  3. 42" LG TV LED Strip Replacement Tutorial: adım 3, 1 resimden 1.
    • Disconnect the ribbon wires from the buffer boards using the provided connectors.
    FixBot'a Sor
    Yorum Ekle
  4. 42" LG TV LED Strip Replacement Tutorial: adım 4, 1 resimden 1.
    • Remove the speakers from the mainboard by disconnecting them from it.
    FixBot'a Sor
    Yorum Ekle
  5. 42" LG TV LED Strip Replacement Tutorial: adım 5, 1 resimden 1.
    • Remove the screws on the assembly that are around the television.
    FixBot'a Sor
    Yorum Ekle
  6. 42" LG TV LED Strip Replacement Tutorial: adım 6, 1 resimden 1.
    • Remove the screws that hold the buffer board in place.
    FixBot'a Sor
    Yorum Ekle
  7. 42" LG TV LED Strip Replacement Tutorial: adım 7, 1 resimden 1.
    • For certain covers, you may need to pry the clips away from the bezel using a five-in-one tool or something similar to free the clips.
    FixBot'a Sor
    Yorum Ekle
  8. 42" LG TV LED Strip Replacement Tutorial: adım 8, 1 resimden 1.
    • Remove the buffer board covers from the board.
    FixBot'a Sor
    Yorum Ekle
  9. 42" LG TV LED Strip Replacement Tutorial: adım 9, 1 resimden 1.
    • To get the buffer boards free, release the tabs on the boards.
    FixBot'a Sor
    Yorum Ekle
  10. 42" LG TV LED Strip Replacement Tutorial: adım 10, 1 resimden 1.
    • Remove the bezel by flipping the television over.
    FixBot'a Sor
    Yorum Ekle
  11. 42" LG TV LED Strip Replacement Tutorial: adım 11, 1 resimden 1.
    • Flip up the buffer boards and tape them to the panel using suction cups.
    FixBot'a Sor
    Yorum Ekle
  12. 42" LG TV LED Strip Replacement Tutorial: adım 12, 1 resimden 1.
    • Remove the panel off the television by lifting it evenly so that it does not break.
    FixBot'a Sor
    Yorum Ekle
  13. 42" LG TV LED Strip Replacement Tutorial: adım 13, 1 resimden 1.
    • Remove the panel frame.
    FixBot'a Sor
    Yorum Ekle
  14. 42" LG TV LED Strip Replacement Tutorial: adım 14, 1 resimden 1.
    • Tape the diffusion layers together at the corner to keep them aligned, then remove the layers of diffusion one by one, starting at the corner.
    FixBot'a Sor
    Yorum Ekle
  15. 42" LG TV LED Strip Replacement Tutorial: adım 15, 1 resimden 1.
    • The reflector is held in place by two sets of tabs located on each side of it.
    FixBot'a Sor
    Yorum Ekle
  16. 42" LG TV LED Strip Replacement Tutorial: adım 16, 1 resimden 1.
    • Pinch the smaller tabs through the chassis on the board side, using needle-nose pliers to get them tight.
    FixBot'a Sor
    Yorum Ekle
  17. 42" LG TV LED Strip Replacement Tutorial: adım 17, 1 resimden 1.
    • Some of the smaller tabs may be placed under the boards; to reach at least one of the smaller tabs, you will need to remove the t-con board.
    FixBot'a Sor
    Yorum Ekle
  18. 42" LG TV LED Strip Replacement Tutorial: adım 18, 1 resimden 1.
    • To release the bigger tabs, you will need to raise one side while sliding it.
    FixBot'a Sor
    Yorum Ekle
  19. 42" LG TV LED Strip Replacement Tutorial: adım 19, 1 resimden 1.
    • Remove the reflector sheet.
    FixBot'a Sor
    Yorum Ekle
  20. 42" LG TV LED Strip Replacement Tutorial: adım 20, 1 resimden 1.
    • Use a five-in-one tool or something similar to disconnect the LED strips from the power cables and pry underneath the LED strips to lift them out of their mounting brackets on the chassis.
    FixBot'a Sor
    Yorum Ekle
  21. 42" LG TV LED Strip Replacement Tutorial: adım 21, 1 resimden 1.
    • Connect the new LED strips and make sure they are properly aligned on the chassis.
    FixBot'a Sor
    Yorum Ekle
  22. 42" LG TV LED Strip Replacement Tutorial: adım 22, 1 resimden 1.
    • Reconnect the LED strips to the power cable as they have been disconnected.
    FixBot'a Sor
    Yorum Ekle
  23. 42" LG TV LED Strip Replacement Tutorial: adım 23, 1 resimden 1.
    • Reconnect the reflector sheet and clips to the reflector frame.
    FixBot'a Sor
    Yorum Ekle
  24. 42" LG TV LED Strip Replacement Tutorial: adım 24, 1 resimden 1.
    • Remove the tape from the layers of diffusion and reinstall them.
    FixBot'a Sor
    Yorum Ekle
  25. 42" LG TV LED Strip Replacement Tutorial: adım 25, 1 resimden 1.
    • Reinstall the panel frame.
    FixBot'a Sor
    Yorum Ekle
  26. 42" LG TV LED Strip Replacement Tutorial: adım 26, 1 resimden 1.
    • Adjust the panel's position and then remove the suction cups.
    FixBot'a Sor
    Yorum Ekle
  27. 42" LG TV LED Strip Replacement Tutorial: adım 27, 1 resimden 1.
    • Release the buffer boards from the tape.
    FixBot'a Sor
    Yorum Ekle
  28. 42" LG TV LED Strip Replacement Tutorial: adım 28, 1 resimden 1.
    • Reinstall the bezel and tighten it down using the screws that run around the perimeter of the TV.
    FixBot'a Sor
    Yorum Ekle
  29. 42" LG TV LED Strip Replacement Tutorial: adım 29, 1 resimden 1.
    • Reinstall the buffer board covers on the board.
    FixBot'a Sor
    Yorum Ekle
  30. 42" LG TV LED Strip Replacement Tutorial: adım 30, 1 resimden 1.
    • Reconnect the t-con board and ribbon wires as they are disconnected.
    FixBot'a Sor
    Yorum Ekle
  31. 42" LG TV LED Strip Replacement Tutorial: adım 31, 1 resimden 1.
    • Reinstall the speakers and connect the wire to the mainboard.
    FixBot'a Sor
    Yorum Ekle
  32. 42" LG TV LED Strip Replacement Tutorial: adım 32, 1 resimden 1.
    • Reinstall the infrared sensor and tighten it to the chassis once more.
    FixBot'a Sor
    Yorum Ekle
  33. 42" LG TV LED Strip Replacement Tutorial: adım 33, 1 resimden 1.
    • Reinstall the back cover and put the screws back in place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Removing and Reinstalling 4G LG TV LED Strips may sound tricky or complicated; however, after reading this tutorial for replacing the LED strips of LG 42inch LED TV, you can do it by yourself now! I hope you enjoy it. See you in the next tutorial.
21 farklı kişi bu kılavuzu tamamladı.
Rachel Burnham
1.101 İtibar
1 Kılavuz yazıldı
5Kılavuz Yorumları
Tv Lg 42lv3500 no se ve imagen , lo único que se ve son líneas de color verticales y luego van desapareciendo hasta quedar en negro , me podrían ayudar por favor
carlos fagundez - Yanıt Paylaş
No one ever shows how to get the wire adapters off the ends of the LED strips! Also, the spacers are very brittle, if you put a 5 in one under it, it will break. Take them off from behind and just push it in a little where the catch is and slide it gently on the face side.
Kevin York - Yanıt Paylaş
My Tv is blank (not showing picture but has a black light display instead of pictures) but still plays sound loud and clear. What could be the problem please? “LG 43" smart. Model 43uk6400plf. Firmware 5.50.15”
AfolabI Olakanmi - Yanıt Paylaş
Mine has the similar situation, no picture shown most the time and whenever picture is on, left half of the screen is flickering with white stripes (on and off) , I thought it might be the display controller's problem but not sure, will someone could guide a direction on how to fix it?
Sherman
Sherman Hsu - Yanıt Paylaş
Hola, mi televisor LG lo apretaron mucho y malogrado la pantalla de tal manera q ahora solo se ven unas línea de colores, no se ve imagen
Janet - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 68
Son 7 gün: 424
Son 30 gün: 1,751
Her zaman: 82,797
