Aletler
Parçalar
Hiçbir parça belirtilmedi.
Take tablet and rotate on its side, so that the two screws are facing upward.
Use Phillips #00 Screwdriver to remove two 1mm screws on the left side of the tablet.
Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
Use soldering gun and when solder is malleable, lift up on the left side of the charge port until it is not connected to the board with tweezers.
Repeat this step on right side of charging port.
Neredeyse bitti!
Sonuç
