Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
To remove the cover of the tablet you will need a plastic prying tool and 1mm Phillips Screwdriver. Be sure to allot roughly 2-3 minutes for the process. If you don't have a plastic prying tool, your fingers should suffice.
Neye ihtiyacın var
Take tablet and rotate on its side, so that the two screws are facing upward.
Use Phillips #00 Screwdriver to remove two 1mm screws on the left side of the tablet.
3 farklı kişi bu kılavuzu tamamladı.
