Ana içeriğe geç
4Sight 9 Motherboard Replacement
Neye ihtiyacın var
  1. 4Sight 9 Motherboard Replacement, Cover: adım 1, 2 resimden 1. 4Sight 9 Motherboard Replacement, Cover: adım 1, 2 resimden 2.
    • Place the tablet on its side so that the two screws are facing upward.
    • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
  2. 4Sight 9 Motherboard Replacement: adım 2, 1 resimden 1.
    • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
    • Once loosened, use your hands to separate the case from the device.
  3. 4Sight 9 Motherboard Replacement: adım 3, 2 resimden 1. 4Sight 9 Motherboard Replacement: adım 3, 2 resimden 2.
    • Hold the positive and negative wires as close as possible to the speaker.
    • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
  4. 4Sight 9 Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
    • For a complete guide on how to solder, click here.
  5. 4Sight 9 Motherboard Replacement: adım 5, 2 resimden 1. 4Sight 9 Motherboard Replacement: adım 5, 2 resimden 2.
    • Grip the ribbon located at the far end of the circuit board with a plastic spudger tool.
    • Put pressure on the connector until the clasp comes undone.
    • Gently pull up on electrical ribbon until it disconnects from circuit board.
  6. 4Sight 9 Motherboard Replacement: adım 6, 2 resimden 1. 4Sight 9 Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the second electrical ribbon from the motherboard.
    • Use the technique for the previous ribbon.
  7. 4Sight 9 Motherboard Replacement: adım 7, 1 resimden 1.
    • Using #00 Phillips Screwdriver, remove the four 1mm screws holding the circuit board to the device.
  8. 4Sight 9 Motherboard Replacement: adım 8, 2 resimden 1. 4Sight 9 Motherboard Replacement: adım 8, 2 resimden 2.
    • With fingers, grip the green Wi-Fi connector.
    • Gently pull up on connector to remove tape holding the connector in place.
  9. 4Sight 9 Motherboard Replacement: adım 9, 1 resimden 1.
    • Using your fingers, gently lift the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 1,347
