Ana içeriğe geç
5 Tips & Tricks
Videoya Genel Bakış
  1. 5 Tips & Tricks, SECRET CODES: adım 1, 3 resimden 1. 5 Tips & Tricks, SECRET CODES: adım 1, 3 resimden 2. 5 Tips & Tricks, SECRET CODES: adım 1, 3 resimden 3.
    • Enter the code from the phone dialer app:
    • *#06# -IMEI number
    • *#1234# - firmware version
    • *#0228# - battery info
  2. 5 Tips & Tricks, HIDDEN TEST MENU: adım 2, 3 resimden 1. 5 Tips & Tricks, HIDDEN TEST MENU: adım 2, 3 resimden 2. 5 Tips & Tricks, HIDDEN TEST MENU: adım 2, 3 resimden 3.
    • Use this code *#0*# to enter the phone into the test menu.
    • From this menu you can run tests for vibration, RGB colors, touch-screen, vibration, loudspeaker output, camera, sensor check and so on.
  3. 5 Tips & Tricks, SAFE MODE: adım 3, 3 resimden 1. 5 Tips & Tricks, SAFE MODE: adım 3, 3 resimden 2. 5 Tips & Tricks, SAFE MODE: adım 3, 3 resimden 3.
    • Switch off the phone.
    • Press and holdthe Volume Down and the Power buttons.
    • When you see the Galaxy logo, release only the Power button
    • Now all third-party apps (apps that are installed by you) are disabled.
    • To exit Safe mode just tap on the Safe mode notification or restart the device manually.
  4. 5 Tips & Tricks, DEVELOPER OPTIONS: adım 4, 3 resimden 1. 5 Tips & Tricks, DEVELOPER OPTIONS: adım 4, 3 resimden 2. 5 Tips & Tricks, DEVELOPER OPTIONS: adım 4, 3 resimden 3.
    • Go to >Menu >Settings >About device, Scroll down to Build number, and tap it seven times.
    • Do not change the options if you do not know what you're doing.
  5. 5 Tips & Tricks, SNAPSHOT: adım 5, 2 resimden 1. 5 Tips & Tricks, SNAPSHOT: adım 5, 2 resimden 2.
    • Press the Power and Home buttons at the same time until a shutter sound is heard or you see a visual indicating a picture was taken.
    • That's all. Did you like this guide?
Sonuç
46 farklı kişi bu kılavuzu tamamladı.
ZFix
191.278 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.528 adet Kılavuz yazıldı
Bir Yorum
How to put mobile internet speed can you have sample code?
Richad Paker - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 18
Her zaman: 20,104
