Ana içeriğe geç
5. Belt Tensioner Assembly
Neye ihtiyacın var
  1. 5. Belt Tensioner Assembly, Left Tensioner Assembly: adım 1, 3 resimden 1. 5. Belt Tensioner Assembly, Left Tensioner Assembly: adım 1, 3 resimden 2. 5. Belt Tensioner Assembly, Left Tensioner Assembly: adım 1, 3 resimden 3.
    • Insert the Left Tensioner slide into the Left Bottom Tensioner mount.
    • Insert M4 hex head screw through the Left Tensioner slide.
    • Make the bearing assembly with 3x M3 washers and 2x F623ZZ bearings.
  2. 5. Belt Tensioner Assembly, Left Tensioner Assembly: adım 2, 3 resimden 1. 5. Belt Tensioner Assembly, Left Tensioner Assembly: adım 2, 3 resimden 2. 5. Belt Tensioner Assembly, Left Tensioner Assembly: adım 2, 3 resimden 3.
    • Insert a M3x18 button head screw to secure the bearing assembly to the tensioner slide.
    • Thread the tensioner knob on to the M4 hex head screw
    • Thread the Left Tensioner Top Plate to the bottom assembly with 2x M3x18 button head screws. Do not tighten completely
  3. 5. Belt Tensioner Assembly, Left Tensioner Assembly: adım 3, 3 resimden 1. 5. Belt Tensioner Assembly, Left Tensioner Assembly: adım 3, 3 resimden 2. 5. Belt Tensioner Assembly, Left Tensioner Assembly: adım 3, 3 resimden 3.
    • Mount the assembly to the left top of the frame using 2x M5x8 button head screws, 2x M5 T-Nuts and 2x M6x10 button head screws. Once the plate is straight tighten the screws
    • Tighten the M3x18 button head screws
    • Secure the bottom of the tensioner to the underside of the 2040 with a M5x8 button head screw and M5 T-Nut
  4. 5. Belt Tensioner Assembly, Right Tensioner Assembly: adım 4, 3 resimden 1. 5. Belt Tensioner Assembly, Right Tensioner Assembly: adım 4, 3 resimden 2. 5. Belt Tensioner Assembly, Right Tensioner Assembly: adım 4, 3 resimden 3.
    • Insert the Right Tensioner slide into the Right Bottom Tensioner mount.
    • Insert M4 hex head screw through the Right Tensioner slide.
  5. 5. Belt Tensioner Assembly, Right Tensioner Assembly: adım 5, 3 resimden 1. 5. Belt Tensioner Assembly, Right Tensioner Assembly: adım 5, 3 resimden 2. 5. Belt Tensioner Assembly, Right Tensioner Assembly: adım 5, 3 resimden 3.
    • Thread the Right Tensioner Top Plate to the bottom assembly with 2x M3x18 button head screws. Do not tighten completely
    • Mount the assembly to the right top of the frame using 2x M5x8 button head screws, 2x M5 T-Nuts and 2x M6x10 button head screws. Once the plate is straight tighten the screws.
Sonuç
I wasn’t paid to write these guides. Ben asked me to do it as a favor to him. Considering all that he’s done for our community I felt it was the least I could do. To be honest even though it took about 2 months to build and document, I had a lot of fun doing it. It forced me to write guides in a manner that was easy for everyone to understand and cleanup my Github so I could share any files that were used that aren’t part of the original download. You’re not obligated but if you would like, feel free to donate.
8 farklı kişi bu kılavuzu tamamladı.
David Husolo
9.162 İtibar
33 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 1,247
