Giriş
This guide is used for the replacement the triggers on your 8BitDo SN30 Pro+ controller. This guide is also used for the replacement Conductive Rubber Pads: L1, L2, R1, R2.
Neye ihtiyacın var
Place the controller face down.
Remove the battery cover.
Remove rechargeable battery or AA batteries.
Remove L2 and R2 trigger buttons by pushing them away from the grips.
Bu adımda kullanılan alet:Tweezers$4.99
Use Tweezers to uncover two screws under the label in the battery compartment.
Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
At the end of each grip, pry apart the covers.
Use fingernail or opening pick to undo the two top clips.
One clip next to L button.
One clip next to R button
Undo the final clip between the joysticks.
Carefully move the rear cover away and from the front cover. Place it to the left.
Unlock the ribbon cable by push open the black plastic tab.
Pull the ribbon cable out of the connector in the direction of the cable.
Use a Phillips screwdriver to remove the seven screws securing the main circuit board.
Six 10.1mm screws
One 5.8mm screws
Slide the R buttons up and off its peg.
Slide the L button up and off its peg.
Remove the main board by rotating it towards the USB-C port. Then lift it out.
Release the three clips holding the trigger assembly to the main board.
Repeat with the other side.
Bend the plastic tab over the locking hook. It helps to push the trigger back slightly, with your other hand.
Gently pry the each side of the trigger out of the round clips.
Both conductive pads are now accessible.
Bir başkası bu kılavuzu tamamladı.
