Ana içeriğe geç
8BitDo Ultimate Wireless D-Pad Replacement
Neye ihtiyacın var
  1. 8BitDo Ultimate Wireless D-Pad Replacement, Case: adım 1, 2 resimden 1. 8BitDo Ultimate Wireless D-Pad Replacement, Case: adım 1, 2 resimden 2.
    • Insert an opening pick into the seam between the left controller grip and main controller body.
    • Pry the grip off.
    • Repeat for the right grip.
    FixBot'a Sor
    Yorum Ekle
  2. 8BitDo Ultimate Wireless D-Pad Replacement: adım 2, 2 resimden 1. 8BitDo Ultimate Wireless D-Pad Replacement: adım 2, 2 resimden 2.
    • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
    FixBot'a Sor
    Yorum Ekle
  3. 8BitDo Ultimate Wireless D-Pad Replacement: adım 3, 3 resimden 1. 8BitDo Ultimate Wireless D-Pad Replacement: adım 3, 3 resimden 2. 8BitDo Ultimate Wireless D-Pad Replacement: adım 3, 3 resimden 3.
    • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
    • Set the halves next to each other with care not to strain the connected ribbon cables.
    FixBot'a Sor
    Yorum Ekle
  4. 8BitDo Ultimate Wireless D-Pad Replacement: adım 4, 3 resimden 1. 8BitDo Ultimate Wireless D-Pad Replacement: adım 4, 3 resimden 2. 8BitDo Ultimate Wireless D-Pad Replacement: adım 4, 3 resimden 3.
    • The ribbon cable is secured with a locking tab connector.
    • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  5. 8BitDo Ultimate Wireless D-Pad Replacement, D-Pad: adım 5, 2 resimden 1. 8BitDo Ultimate Wireless D-Pad Replacement, D-Pad: adım 5, 2 resimden 2.
    • Remove the seven 5 mm Phillips #00 screws securing the PCB to the top shell, then lift the board out.
    FixBot'a Sor
    Yorum Ekle
  6. 8BitDo Ultimate Wireless D-Pad Replacement: adım 6, 1 resimden 1.
    • Carefully lift the D-pad conductive pad out of the shell.
    FixBot'a Sor
    Yorum Ekle
  7. 8BitDo Ultimate Wireless D-Pad Replacement: adım 7, 2 resimden 1. 8BitDo Ultimate Wireless D-Pad Replacement: adım 7, 2 resimden 2.
    • Remove the directional pad.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Alexander Garcia
473 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Biswokarma Spring 2026 UMass Dartmouth, Team 1-3, Biswokarma Spring 2026 üyesi
UMASSD-BISWOKARMA-S26S1G3
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 106
