Giriş
Use this guide to replace a faulty joystick component on the 8Bitdo N30 Arcade Stick without damaging the Retro game controller.
A Phillips #0 screwdriver and a flathead 3/32” screwdriver are required to remove screws.
No special skills are required. Take caution in regards to removing and organizing the pieces of the 8Bitdo N30 Joystick when you are replacing the joystick.
Neye ihtiyacın var
Follow the steps in reverse order to install the new joystick.
Once again, don’t forget the rubber slider for the back panel.
Boot up your favorite PC or Nintendo Switch fighting game and make sure your joystick works!
2 farklı kişi bu kılavuzu tamamladı.
