Ana içeriğe geç
8Bitdo N30 Joystick Replacement
Neye ihtiyacın var
  1. 8Bitdo N30 Joystick Replacement, Joystick: adım 1, 2 resimden 1. 8Bitdo N30 Joystick Replacement, Joystick: adım 1, 2 resimden 2.
    • Turn the device over so that the bottom of the device is facing up.
  2. 8Bitdo N30 Joystick Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove all ten of the 3 mm screws on the back plate.
  3. 8Bitdo N30 Joystick Replacement: adım 3, 2 resimden 1. 8Bitdo N30 Joystick Replacement: adım 3, 2 resimden 2.
    • Remove the rubber slider from the device.
    • Hold the arcade stick and pry the back panel away from the device until it comes off.
    • Remember the position of the rubber slider; it will be replaced at the end of the process.
  4. 8Bitdo N30 Joystick Replacement: adım 4, 2 resimden 1. 8Bitdo N30 Joystick Replacement: adım 4, 2 resimden 2.
    • Locate the back piece of the joystick.
    • Remove the four screws that secure the joystick using the Phillips #0 screwdriver.
  5. 8Bitdo N30 Joystick Replacement: adım 5, 2 resimden 1. 8Bitdo N30 Joystick Replacement: adım 5, 2 resimden 2.
    • Use a flathead screwdriver to remove the middle screw that holds the ball piece onto the joystick.
    • Remove the ball piece and set it aside.
    • Be sure to hold the ball piece in place while turning the screw counterclockwise.
    • When attaching the new joystick and ball piece, turn the screw clockwise while holding the ball piece in place.
  6. 8Bitdo N30 Joystick Replacement: adım 6, 3 resimden 1. 8Bitdo N30 Joystick Replacement: adım 6, 3 resimden 2. 8Bitdo N30 Joystick Replacement: adım 6, 3 resimden 3.
    • Locate the joystick wires that are attached to the four plugs on the motherboard and disconnect them.
    • In fine print, "left," "down," "up," and "right" are found above the wires that need to be removed.
    • Take caution and gently disconnect the wires.
  7. 8Bitdo N30 Joystick Replacement: adım 7, 2 resimden 1. 8Bitdo N30 Joystick Replacement: adım 7, 2 resimden 2.
    • Remove the back piece from the mounting plate.
    • Replace the joystick's back piece.
Sonuç
Follow the steps in reverse order to install the new joystick.
Once again, don’t forget the rubber slider for the back panel.
Boot up your favorite PC or Nintendo Switch fighting game and make sure your joystick works!
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
looks just like the mayflash f300
Jon Hernandez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 35
Her zaman: 2,300
