Giriş
The form of the candle lamp is exquisite, presenting a blend of simplicity and fashion. Constructed from mild steel sheet, this product boasts durability and easy maintenance. Its operational mechanism involves utilizing a light bulb for heating, which effectively accelerate the candle's surface. The switch is a knot design ,by rotating, the temperature and brightness of the light can be adjusted to the desired levels.
Neye ihtiyacın var
The product before teardown
From its initial look, it can mainly separate into four parts. The top ( lamp shade) , the stand ( the tube ) , the base and the wire & controller.
Overall product dimension : 290 x 185x 150mm . Weight : 585 gram
The back of the lamp base was pulled off and flipped over revealing the base structure. Here a craft knife was used for the removal.
The cap functions as a cover to hide the cable , its material is High-density Polyethylene ( HDPE) and is injection molded.
The dimension is 15cm diameter x5mm thickness , its weight is 29g.
The white lock to secure the wire and it was removed by a grip and a wire cutter
The lamp base is a platform for a candle to sit on top, this view is a close up to see where does the cable goes
The lamp base is made of mild steel and it’s about 15cm diameter x2.7cm height with 142grams in weight.
The hex nut was removed by the spanner.
The number 6 spanner was used
Remove the screws inside the light bulb connector
The screws are machined made and the type of screws is a mushroom-head with 4mm head diameter 10mm tall.
Cut the connector head and pull out the cable after removing the nut from both sides
The image showed a light bulb connector and its probably a HDPE or Acrylonitrile Butadiene Styrene (ABS) plastic , injection melded , overall dimension is 28mm diameter x 17mm in height
Remove the control panel case by unfastening the screw
The case functions to protect damages from the circuit board and it’s made by ABS/ HDPE , injection molded with an overall dimension 900mm length x 400 width x10 height, 21gram in weight
Pull out the cable from the tube
The cable jacket is PVC , 1230mm length with 6mm thickness , weigh in 78gram
Separate parts : the nuts , the lamp stand, the lamp shade , the base, the controller case , the dimmerable knot and the screws
Here is the small component close-up shot of the diassembly of the candle lamp
Finished the product teardown. There are about 14 components of it.
