Ana içeriğe geç
AARP RealPad MA7BX2 Screen Replacement
Neye ihtiyacın var
  1. AARP RealPad MA7BX2 Screen Replacement, Back Cover: adım 1, 2 resimden 1. AARP RealPad MA7BX2 Screen Replacement, Back Cover: adım 1, 2 resimden 2.
    • Loosen the back cover using the suction cup.
    • Pull up on the center of the back with the suction cup.
    • Pull up on all four corners of the back with the suction cup.
  2. AARP RealPad MA7BX2 Screen Replacement: adım 2, 1 resimden 1.
    • Remove the back cover by gently placing the small opening tool in the crevice created by loosening the back.
    • Slide the opening tool around the edges of the device.
    • Wedge it open using the opening tool.
    • Use the suction cup again if you're having trouble removing the back cover.
  3. AARP RealPad MA7BX2 Screen Replacement: adım 3, 2 resimden 1. AARP RealPad MA7BX2 Screen Replacement: adım 3, 2 resimden 2.
    • The black tape is stuck to delicate wires; remove with caution.
    • Peel off the silver tape.
    • Gently pull off the black tape.
  4. AARP RealPad MA7BX2 Screen Replacement: adım 4, 2 resimden 1. AARP RealPad MA7BX2 Screen Replacement: adım 4, 2 resimden 2.
    • Using a JIS #000 screwdriver, remove the two 2.5 mm screws.
  5. AARP RealPad MA7BX2 Screen Replacement: adım 5, 2 resimden 1. AARP RealPad MA7BX2 Screen Replacement: adım 5, 2 resimden 2.
    • Lift off the black audio cover.
  6. AARP RealPad MA7BX2 Screen Replacement, Motherboard: adım 6, 2 resimden 1. AARP RealPad MA7BX2 Screen Replacement, Motherboard: adım 6, 2 resimden 2.
    • Remove the two JIS #000 screws.
  7. AARP RealPad MA7BX2 Screen Replacement: adım 7, 2 resimden 1. AARP RealPad MA7BX2 Screen Replacement: adım 7, 2 resimden 2.
    • Flip up the small black connectors using a spudger or your nails.
    • Be careful when flipping them up. Too much force can cause them to break.
  8. AARP RealPad MA7BX2 Screen Replacement: adım 8, 1 resimden 1.
    • Remove battery.
    • Removing the battery may need some force. Be careful as to not break anything.
  9. AARP RealPad MA7BX2 Screen Replacement: adım 9, 2 resimden 1. AARP RealPad MA7BX2 Screen Replacement: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use the tweezers to loosen up the sides of speakers by going into the gaps, before picking it up.
    • There are magnets holding down the speakers. Be careful as to not pick them up with the speakers.
    • The top of the speakers are very fragile and may fall out at the slightest touch. Be careful when picking them up.
  10. AARP RealPad MA7BX2 Screen Replacement: adım 10, 2 resimden 1. AARP RealPad MA7BX2 Screen Replacement: adım 10, 2 resimden 2.
    • Remove all wire connections by sliding them out of the connectors.
    • Be careful as to not forcefully pull out anything because the wires are very delicate.
  11. AARP RealPad MA7BX2 Screen Replacement: adım 11, 1 resimden 1.
    • Take off the motherboard and set it aside. Your Finished product should look like this.
  12. AARP RealPad MA7BX2 Screen Replacement, Screen: adım 12, 3 resimden 1. AARP RealPad MA7BX2 Screen Replacement, Screen: adım 12, 3 resimden 2. AARP RealPad MA7BX2 Screen Replacement, Screen: adım 12, 3 resimden 3.
    • Use the suction cup to loosen and pull up the screen.
    • Be careful when pulling up screen. Too much force can lead to you breaking it.
Sonuç
Alana Escue
425 İtibar
3 adet Kılavuz yazıldı
1Rehber Yorum
Remember to give the lengths for all screws. For warnings, try to be more straight forward and try not to use words like '“note.” Remember to add an introduction.
Jackson Reynolds - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 667
