Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Loosen the back cover using the suction cup.
Pull up on the center of the back with the suction cup.
Pull up on all four corners of the back with the suction cup.
Remove the back cover by gently placing the small opening tool in the crevice created by loosening the back.
Slide the opening tool around the edges of the device.
Wedge it open using the opening tool.
Peel off the silver tape.
Gently pull off the black tape.
Using a JIS #000 screwdriver, remove the two 2.5 mm screws.
Flip up the small black connectors using a spudger or your nails.
Use the tweezers to loosen up the sides of speakers by going into the gaps, before picking it up.
Remove all wire connections by sliding them out of the connectors.
Take off the motherboard and set it aside. Your Finished product should look like this.
Bir Yorum
Remember to give the lengths for all screws. For warnings, try to be more straight forward and try not to use words like '“note.” Remember to add an introduction.
