Ana içeriğe geç
ACER Aspire 7750G-6645 Hard Drive Replacement
Neye ihtiyacın var
  1. ACER Aspire 7750G-6645 Hard Drive Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove three 60mm Phillips #00 screws that are holding the bottom cover in place.
  2. ACER Aspire 7750G-6645 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Lift up the back cover of the device, you may need to use a spudger to assist.
  3. ACER Aspire 7750G-6645 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 1. ACER Aspire 7750G-6645 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 2. ACER Aspire 7750G-6645 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 3.
    • Remove two 4mm Phillips #00 screws that are holding the hard drive in place.
  4. ACER Aspire 7750G-6645 Hard Drive Replacement: adım 4, 2 resimden 1. ACER Aspire 7750G-6645 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Push the hard drive to the right and push it upward to remove. You may need a spudger or plastic opening tool to assist you with this step.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Thong
199 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G2, Botvin Spring 2019 UMass Dartmouth, Team S1-G2, Botvin Spring 2019 üyesi
UMASSD-BOTVIN-S19S1G2
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 2,225
