Ana içeriğe geç
ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement
Neye ihtiyacın var
  1. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement, Battery: adım 1, 1 resimden 1.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip your laptop over so the back panel is facing upwards.
    • Locate the lock switch below the battery.
  2. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: adım 2, 3 resimden 1. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: adım 2, 3 resimden 2. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: adım 2, 3 resimden 3.
    • Slide the lock switch to the right using your finger or a spudger.
    • At the same time, grasp the battery with your other hand and slide it out of the laptop.
    • Remove the battery.
    • To reinsert or replace the battery, simply line up the tabs on the battery with the laptop and slide it straight back in. There is no need to move the lock switch.
  3. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement, Hard Drive (HDD): adım 3, 1 resimden 1.
    • Unscrew the one 8mm Phillips #0 screw from the bottom panel.
  4. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: adım 4, 3 resimden 1. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: adım 4, 3 resimden 2. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: adım 4, 3 resimden 3.
    • Remove the back panel by carefully disengaging it around the edges and then pulling upwards.
  5. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: adım 5, 1 resimden 1.
    • Remove the other 8mm Phillips #0 screw holding the hard drive to the rest of the laptop.
  6. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: adım 6, 2 resimden 1. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: adım 6, 2 resimden 2.
    • Slide the hard drive to the left using a plastic opening tool.
  7. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: adım 7, 3 resimden 1. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: adım 7, 3 resimden 2. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: adım 7, 3 resimden 3.
    • To remove the hard drive, pull up and to the left using the plastic tab as shown on the left side of the hard drive.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Cody Lim
1.404 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-6, Banghart Winter 2017 Cal Poly, Team 9-6, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S9G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 3,582
