Giriş
This guide will show you how to properly remove the keyboard.
Neye ihtiyacın var
Flip your laptop over so the back panel is facing upwards.
Locate the lock switch below the battery.
Separate the top panel from the rest of the laptop.
Remove the yellow tape and then remove the three 1.4 x 2 mm Phillips #00 screws with a Phillips #00 screwdriver.
7 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
If installing a new keyboard, remember to pull the keyboard cable through the metal panel before screwing it back in.
