Giriş
This guide will show you how to properly remove the keyboard.
Neye ihtiyacın var
Flip your laptop over so the back panel is facing upwards.
Locate the lock switch below the battery.
Remove the 16 2.5 x 8mm Phillips #0 screws from the back panel.
If you just want to replace the screen then skip this step and all the following steps up to Step 13.
I’ve followed this procedure several times trying to fix a dodgy screen on the same laptop. After the 4th time I realised that you do not need to disassemble the base part of the laptop at all. Just skip to Step 13, remove the 2 hinge screws and pull off the black screen surround. It needs a bit of jiggling but its much, much easier than trying to fight with the 3 ribbon cable connectors for the keyboard.
If you do actually need to replace the screen cable, then you have to follow the complete process.
The sides and front edge of the top panel have a lot of moulded in clips holding the top onto the bottom. I needed a spludger to lever the sides of the bottom case out to release the clips from the top
Lift the top panel all the way up and your laptop is now split into its two distinct halves.
Thank you, I found the instructions straight forward and easy to understand. Good step by step and photos easy to see. I would use other instructions presented by you. Alan Keirle
Can you show me where the power button is on the inside of my acer e1572-6484. I have tried everything to turn on and start my laptop, which turned on before i disassembled it to reset the CMOS battery. I connected everything. The led light is on indicating fully charged. new RAMS ac charger and battery pack. HELP!
By the way regarding my Acer e1572-6484, after opening it I found it did not have an CMOS battery to reset.
Separate the top panel from the rest of the laptop.
Remove the yellow tape and then remove the three 1.4 x 2 mm Phillips #00 screws with a Phillips #00 screwdriver.
7 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
If installing a new keyboard, remember to pull the keyboard cable through the metal panel before screwing it back in.
