Ana içeriğe geç
ACER Aspire V5-571P-6609 RAM Replacement
Neye ihtiyacın var
  1. ACER Aspire V5-571P-6609 RAM Replacement, RAM: adım 1, 3 resimden 1. ACER Aspire V5-571P-6609 RAM Replacement, RAM: adım 1, 3 resimden 2. ACER Aspire V5-571P-6609 RAM Replacement, RAM: adım 1, 3 resimden 3.
    • Make sure you completely power off the device before proceeding.
    • Turn over the device to display the back cover and remove the two marked Phillips #0 screws.
  2. ACER Aspire V5-571P-6609 RAM Replacement: adım 2, 3 resimden 1. ACER Aspire V5-571P-6609 RAM Replacement: adım 2, 3 resimden 2. ACER Aspire V5-571P-6609 RAM Replacement: adım 2, 3 resimden 3.
    • Once the screws have been removed, utilize a jimmy tool to pry open the back cover. Carefully lift the cover and set it aside for now.
  3. ACER Aspire V5-571P-6609 RAM Replacement: adım 3, 3 resimden 1. ACER Aspire V5-571P-6609 RAM Replacement: adım 3, 3 resimden 2. ACER Aspire V5-571P-6609 RAM Replacement: adım 3, 3 resimden 3.
    • With two fingers, push the latches holding the DIMM to the sides.
    • The DIMM will tilt upward once it is released from the slot.
    • Carefully secure the DIMM and remove it.
  4. ACER Aspire V5-571P-6609 RAM Replacement: adım 4, 3 resimden 1. ACER Aspire V5-571P-6609 RAM Replacement: adım 4, 3 resimden 2. ACER Aspire V5-571P-6609 RAM Replacement: adım 4, 3 resimden 3.
    • Repeat the same process from the previous step for the second slot.
  5. ACER Aspire V5-571P-6609 RAM Replacement: adım 5, 2 resimden 1. ACER Aspire V5-571P-6609 RAM Replacement: adım 5, 2 resimden 2.
    • Insert the replacement DIMM into the slot.
    • Once inserted, push the DIMM down gently until it snaps into place.
  6. ACER Aspire V5-571P-6609 RAM Replacement: adım 6, 3 resimden 1. ACER Aspire V5-571P-6609 RAM Replacement: adım 6, 3 resimden 2. ACER Aspire V5-571P-6609 RAM Replacement: adım 6, 3 resimden 3.
    • Place the cover back on.
    • Insert the screws back into place with a screwdriver.
Sonuç
To reassemble your device, follow these instructions in reverse order with new RAM cards.
Ernesto Pacheco
277 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Pee Fall 2022 Gateway, Team 1-1, Pee Fall 2022 üyesi
GCC-PEE-F22S1G1
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 35
Her zaman: 275
