Ana içeriğe geç
ACER Aspire V5-571P-6609 Touchpad Replacement
Neye ihtiyacın var
  1. ACER Aspire V5-571P-6609 Touchpad Replacement, Touchpad: adım 1, 3 resimden 1. ACER Aspire V5-571P-6609 Touchpad Replacement, Touchpad: adım 1, 3 resimden 2. ACER Aspire V5-571P-6609 Touchpad Replacement, Touchpad: adım 1, 3 resimden 3.
    • Close the laptop and flip over. Locate battery slide release. This guide marks the location with a red circle.
    • Use a pointed tool (we used a screwdriver) to slide release to the right when facing the laptop from the non-battery side.
    • Gently pull the battery away from the laptop with the slide release held open.
  2. ACER Aspire V5-571P-6609 Touchpad Replacement: adım 2, 1 resimden 1.
    • Remove the two Phillips #0 screws.
    • Once all necessary screws are removed, turn the laptop over and open it.
  3. ACER Aspire V5-571P-6609 Touchpad Replacement: adım 3, 3 resimden 1. ACER Aspire V5-571P-6609 Touchpad Replacement: adım 3, 3 resimden 2. ACER Aspire V5-571P-6609 Touchpad Replacement: adım 3, 3 resimden 3.
    • Slide a Jimmy tool between the top of the keyboard and the outer panel, then gently pop the top tabs out of place.
    • Carefully detach the two flex cables before fully lifting keyboard out in order to avoid cable damage.
    • Once cables are safely detached, lift the keyboard off of the laptop and place it on a safe, non-static surface.
  4. ACER Aspire V5-571P-6609 Touchpad Replacement: adım 4, 3 resimden 1. ACER Aspire V5-571P-6609 Touchpad Replacement: adım 4, 3 resimden 2. ACER Aspire V5-571P-6609 Touchpad Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the six Phillips #0 screws.
    • Flip up the plastic lock bar mechanism securing the two ribbon cables.
    • Gently pull the cables out of their ports with tweezers.
  5. ACER Aspire V5-571P-6609 Touchpad Replacement: adım 5, 3 resimden 1. ACER Aspire V5-571P-6609 Touchpad Replacement: adım 5, 3 resimden 2. ACER Aspire V5-571P-6609 Touchpad Replacement: adım 5, 3 resimden 3.
    • Slide a Jimmy in between the front and back panel of the laptop
    • Slowly rotate the Jimmy tool in hand until the top panel pops loose. Repeat on all sides until the top panel is free of the main body.
    • Gently lift the top panel free of the main body.
  6. ACER Aspire V5-571P-6609 Touchpad Replacement: adım 6, 3 resimden 1. ACER Aspire V5-571P-6609 Touchpad Replacement: adım 6, 3 resimden 2. ACER Aspire V5-571P-6609 Touchpad Replacement: adım 6, 3 resimden 3.
    • Flip the top panel over and locate the touchpad.
    • Flip up the connector's lock bar from the touchpad, then disconnect the cable.
    • Peel down the adhesive tape securing the touchpad and remove the three Phillips #0 screws securing the touchpad.
  7. ACER Aspire V5-571P-6609 Touchpad Replacement: adım 7, 3 resimden 1. ACER Aspire V5-571P-6609 Touchpad Replacement: adım 7, 3 resimden 2. ACER Aspire V5-571P-6609 Touchpad Replacement: adım 7, 3 resimden 3.
    • Once screws have been removed, place fingers under and over the touchpad and slowly push it up; firmly hold the touchpad as it is being removed.
    • Replace the touch pad with a new touchpad.
Sonuç
Ernesto Pacheco
277 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Pee Fall 2022 Gateway, Team 1-1, Pee Fall 2022 üyesi
GCC-PEE-F22S1G1
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 39
Her zaman: 260
