Ana içeriğe geç
ACN Iris WG4K Blade Connector Replacement
Neye ihtiyacın var
  1. ACN Iris WG4K Blade Connector Replacement, Handset: adım 1, 2 resimden 1. ACN Iris WG4K Blade Connector Replacement, Handset: adım 1, 2 resimden 2.
    • Press upwards with your index finger on the 4P4C connector as shown in the image.
    • Pull the connector gently out of its socket.
  2. ACN Iris WG4K Blade Connector Replacement, Lower Case: adım 2, 1 resimden 1.
    • Flip the main body of the video phone so that the bottom is facing up.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
  3. ACN Iris WG4K Blade Connector Replacement: adım 3, 2 resimden 1. ACN Iris WG4K Blade Connector Replacement: adım 3, 2 resimden 2.
    • Lift the back case upwards to expose the inside components.
    • Red rectangles indicate the three ribbon cables.
    • The orange square indicates the blade connector.
  4. ACN Iris WG4K Blade Connector Replacement: adım 4, 3 resimden 1. ACN Iris WG4K Blade Connector Replacement: adım 4, 3 resimden 2. ACN Iris WG4K Blade Connector Replacement: adım 4, 3 resimden 3.
    • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull the ribbon cables out of their insulation-displacement connectors.
  5. ACN Iris WG4K Blade Connector Replacement: adım 5, 2 resimden 1. ACN Iris WG4K Blade Connector Replacement: adım 5, 2 resimden 2.
    • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
    • Gently pull the blade connector out of the blade receptacle.
  6. ACN Iris WG4K Blade Connector Replacement: adım 6, 1 resimden 1.
    • Gently lift up the lower case to separate it from the top case.
  7. ACN Iris WG4K Blade Connector Replacement, Blade Connector: adım 7, 1 resimden 1.
  8. ACN Iris WG4K Blade Connector Replacement: adım 8, 1 resimden 1.
    • Gently lift up on the upper case to separate it from the keypad/speaker panel.
  9. ACN Iris WG4K Blade Connector Replacement: adım 9, 1 resimden 1.
    • Use the Phillips #0 Screwdriver to remove the two Phillips head screws (5 mm) located on the upper case.
  10. ACN Iris WG4K Blade Connector Replacement: adım 10, 1 resimden 1.
    • Rotate the top case 180 degrees so that the video screen is closest to you.
    • Lift up the bottom up so that it is perpendicular to the table (this helps you reach the two top screws).
    • The four Phillips head screws (6 mm) are highlighted by the red circles.
  11. ACN Iris WG4K Blade Connector Replacement: adım 11, 1 resimden 1.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm).
  12. ACN Iris WG4K Blade Connector Replacement: adım 12, 1 resimden 1.
    • Flip the top case so that the video screen is facing up.
  13. ACN Iris WG4K Blade Connector Replacement: adım 13, 1 resimden 1.
    • Rotate the top case 180 degrees.
    • Gently lift up on the video screen and the blade and ribbon connector to give you more slack to work with.
  14. ACN Iris WG4K Blade Connector Replacement: adım 14, 1 resimden 1.
    • Place the video screen face down to expose the two screws. The screws are indicated by the red circles.
  15. ACN Iris WG4K Blade Connector Replacement: adım 15, 2 resimden 1. ACN Iris WG4K Blade Connector Replacement: adım 15, 2 resimden 2.
    • Use the Phillips #0 Screwdriver to remove the two Phillips head screws (6 mm)
  16. ACN Iris WG4K Blade Connector Replacement: adım 16, 2 resimden 1. ACN Iris WG4K Blade Connector Replacement: adım 16, 2 resimden 2.
    • Pull the ribbon connector and blade connector through the top case.
Sonuç
Itze Kenney
1.066 İtibar
9 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 20-4, Remmell Spring 2017 USF Tampa, Team 20-4, Remmell Spring 2017 üyesi
USFT-REMMELL-S17S20G4
4 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 246
